Question about Dell Inspiron 6000 Notebook
Dell shut down automaticly can someone help
Can someone help.
  • 231 Answers
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Posted on Dec 24, 2008
  • Suzanne
    Suzanne Dec 24, 2008
    Spontaneous shutdown and restarting problems are also due to a faulty battery. If your laptop is more than 2-3 years old, this has been known for unwanted shutdowns, restarts, or freezes. To validate if you have a faulty battery that is causing the issue, remove the battery and operate the laptop directly from the power adapter to see if you still experience the shutdown or reboot. If it goes away, you have a faulty battery.
Dell laptop automatically logs off immidiately after start up
Do you have an active antivirus software on it? It maybe due to mal ware or trojan You take it to a specialist to get the hard disc Scanned
Dec 13, 2013 | Dell Inspiron Computers & Internet
Dell inspiron 1521 has to be shut down manually
there are two settings in the bios that need to be changed....one is the automatic sleep/shutdown and the other is the remote wake-up
May 16, 2012 | Dell Inspiron 1521 Notebook
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My laptop automatically shuts down after i turned
My new dell inspiron 14r laptop with windows 7 is suddenly getting shuts down plz help me
Jun 20, 2010 | CMB T43 750 Notebook
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
My Dell D610 is always on when I get to work
if you are using Windows Vista, you might haven't shut down your system. Make sure that you did click the Shut Down link at the menu.
Jul 09, 2009 | Dell Latitude D610 Notebook
Automatic shutdown problem with my DELL laptop
Sounds like you need more ram,,or your processor is too slow.
Jan 19, 2009 | Dell Inspiron 6000 Notebook
Override Dell Latitude D600 laptop automatically shutting down
yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
Turn of the display> change to four hours
Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
I hope this helps
Jan 10, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6000 Notebook Logo
354 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
