Foxconn or my processor fried while i tried to overclock my comp
I tried to overclock my amd 64 x2 6000 processor. and i follow the direction and the support at foxconn speaks chinease and i dont know what to do
  • xpok7 May 11, 2010
    Did you overclock it from Windows or in the BIOS. You're supposed to do it in BIOS.
  • Dan rogers
    Dan rogers May 11, 2010
    do about what if you fried it you need to look up your motherboard and buy a new chip that is compatible.
  • 11,800 Answers
Foxconn are miserable at overclocking and X2 - 6000 is a proc already overclocked from factory - you can't push it any further without a serious water cooler.
Reset the BIOS and hope it will start again, otherwise you will need at least a new proc.
Posted on Mar 30, 2010
EMachine EL1333G windows 7 64 bit AMD Athlon 2650E Processor ( BIOS OVERCLOCK HELP)
What type of cooling do you have currently? How fast do you want it to go? What options does your BIOS offer?
Apr 23, 2013 | E-Machines eMachines Desktop PC
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
Does Foxconn 6100M2MA-RS2H Motherboard BIOS support AMD Phenom 64 X4 procesor ?
I'm afraid not. Foxconn 6100M2MA-RS2H has an AM2 Socket that only supports the following processors: AMD Sempron, Athlon 64,Athlon 64x2,Athlon 64FX. Phenom processors support AM2+ and AM3 socket motherboards. Hope this helps. Any vote will be appreciated. Thank you :)
May 30, 2011 | Foxconn 6100M2MA-RS2H Motherboard
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Fast processor's speed
Your motherboard accepts Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
The board has safe overclocking - so unless you know what you're doing I would stay away from changing any settings manually or you could fry the mobo.
How much memory do you have - more memory can increase speed. Faster HDD
If you want you could go for the Athlon 64,
The Sempron only goes to 2.31 so there wouldn't be much difference in speed.
Apr 25, 2009 | Computers & Internet
I have no idea in overclocking my PC
Download AMD Overdrive here
It is a powerful all-in-one overclocking, monitoring, and testing utility designed for users of motherboards with AMD 700-series chipsets.
Mar 11, 2009 | MSI 6600GT 128M VIVO/TV/DVI OVERCLOCKING...
Overclocking
I never overclock my processors... because I have fried a couple.
AND I don't really need any extra power/speed... because now I only surf the web and do some Word/Excel stuff and my duo core Intel chip is awesome for that.
So - first: I don't recommend it.
But - second: there are some good sources on the web about it...
Do you know how to do it?
I mean the steps to get to the settings and change them?
If you do then I found some recommendations for your processor at http://www.amdgeeks.net/overclockdatabase.
Processor: Athlon 64 LE-1640 2600 @ 3422 MHz
Overclock % Voltage Idle Load
132% 1.25/35/40 @ 1.50V 35°C 41°C
Processor: Athlon 64 LE-1640 2600 @ 3380 MHz
130% 1.25/35/40 @ 1.40V 30°C 40°C
Processor: Athlon 64 LE-1640 2600 @ 3320 MHz
128% 1.25/35/40 @ 1.37V 29°C 44°C
Like I said I don't recommend it so I don't want to walk you through it, also when you do this you run a risk of frying your chip - and I don' want to be liable. Like I said above - there is some good infor on the web about it so you should not have any trouble finding out how if you don't know.
Good luck
Jan 03, 2009 | Acer Computers & Internet
Overclock procesor athlon 64 2800 +?
There are a bunch of guides out there to help you with the overclocking process.But bear in mind that you will loose your warranty as son as you change the frequency cycles. Also make sure that your system can withstand the excessive heat that will be generated by the processor.You should arrange some alternative cooling system like liquid coolers,Highgraded thermal insulation pastes or atleast a couple of additional coolant fans. Go through this.... http://www.hardwaresecrets.com/article/102
Nov 03, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Can the amd athlon 4200 x2 proceesor be overclocked ? on the geforce6100pm-m2 motherboard
not a good idea over clock it to much without the right cpu heat sink and faster fan will make it over heat and possably blow up it should work with 2.4 if not u need at least a 450 watt power supply with that card
Oct 26, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Compatible Processors
Can only support Processor: Socket 939 for AMD Athlon™ 64 and 64 FX processors
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 22, 2007 | Foxconn NF4K8AC-RS-1.0 Motherboard
Computers & Internet Logo
120 people viewed this question
Alun Cox
David Payne
David Payne
