Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
Radio will not turn on w/full battery
I have an FT-51R and when I try to turn it on nothing happens, what could the problem be. I had the battery power checked and it's OK.
Carfully clean the contacts on the battery and the power contacts on the radio. I have had the same problem, and this fixed it for me.
Posted on Mar 04, 2009
2 Suggested Answers
SOURCE: I have an FT-51R and
Carefully clean the contacts on the battery and the radio. The contact area is so small that the slightest amount of oxidation or corrosion will prevent the radio from working.
I'am having some problems with vxa-100 getting verry hot
The walkie talkie is the heat sink. So on extended talk times, it will get hot. So will the battery. If you run full power, it is only worse. That said, some batteries will become abnormally hot with use. Usually OEM batteries are higher quality cells and seem to get a little less hot. Never buy the cheapest battery for a handheld radio. Some are pure junk.
Mar 25, 2013 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Will only work in the 144.000 - 146.000 range
That is the spec range for this radio. You may be able to find instructions to operate "out of band" on "www.mods.dk".
Aug 12, 2011 | Vertex FNB-35M,...
Reset vx 5
Turn your VX-5 off, then press Band + HM/RV + TX PO and turn on.
May 29, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
FT-11r no longer powers up with a known fully charged battery ? The battery was left in the unit a couple of months with a discharged battery. Could this have damaged the unit ?
It's unlikely leaving the battery pack attached ruined the radio, unless it leaked and corroded the contacts. Be sure they're clean and bright. Double check to be sure the battery pack really is charged to rated voltage.
Oct 09, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
After factory reset of yaesu vx-5 can not get out of nfm
Check the frequency step setting. If you have it set to 12.5kHz it's possible that's forcing the nfm mode.
Dec 26, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I have an FT-51R and when I try to turn it on with a full battery nothing happens
Dec 24, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Jul 14, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
307 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
