Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
I have an FT-51R and when I try to turn it on with a full battery nothing happens
Carefully clean the contacts on the battery and the radio. The contact area is so small that the slightest amount of oxidation or corrosion will prevent the radio from working.
Posted on Mar 04, 2009
2 Suggested Answers
SOURCE: Radio will not turn on w/full battery
Carfully clean the contacts on the battery and the power contacts on the radio. I have had the same problem, and this fixed it for me.
I'am having some problems with vxa-100 getting verry hot
The walkie talkie is the heat sink. So on extended talk times, it will get hot. So will the battery. If you run full power, it is only worse. That said, some batteries will become abnormally hot with use. Usually OEM batteries are higher quality cells and seem to get a little less hot. Never buy the cheapest battery for a handheld radio. Some are pure junk.
Mar 25, 2013 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Will only work in the 144.000 - 146.000 range
That is the spec range for this radio. You may be able to find instructions to operate "out of band" on "www.mods.dk".
Aug 12, 2011 | Vertex FNB-35M,...
My battery died because my kiddo left the back door open. I went to walmart and bought a 51R-4, instead of the 51R they had in the vehicle. Would that make any difference in whether or not the car will...
I dont know what the 4 means unless its a 4 year warranty?? but that should not make a difference. There should be some large fuses in the fuse box, if anyone tried to jump sart it, they could have blown the main fuse, like 100amp
Nov 18, 2010 | 2005 Honda Element
I want a manual for a yaesu vx-5
You can probably find it on www.mods.dk - you may pay a small fee, but they have manuals for most ham radios.
Sep 27, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Reset vx 5
Turn your VX-5 off, then press Band + HM/RV + TX PO and turn on.
May 29, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
FT-11r no longer powers up with a known fully charged battery ? The battery was left in the unit a couple of months with a discharged battery. Could this have damaged the unit ?
It's unlikely leaving the battery pack attached ruined the radio, unless it leaked and corroded the contacts. Be sure they're clean and bright. Double check to be sure the battery pack really is charged to rated voltage.
Oct 09, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Dec 24, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Jul 14, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
298 people viewed this question
Top Vertex Radio Communications Experts
eradiostore
eradiostore
k24674
Sheldon Dedek
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
