Question about HP Compaq nc6230 Notebook
1781 disk 1 failure
Hi ,
I am not able to boot by laptop ,It is giving error "1781 disk 1 failure "
Please some one help me .
  • Manish_annu Dec 26, 2008
    HD test built into the BIOS is 100 % OK .
    Problem Solver:
  • 15 Answers
It could be the HD failing, the onboard controller failing (meaning the motherboard, or more importantly the laptop is toast), or it might simply be that the HD connection to the controller just needs to be reseated. The first thing to try is the HD test built into the BIOS. It should give a clearer idea of what is actually happening to the LT.
Posted on Dec 26, 2008
Hello when I try start my laptop I get a little blue box saying : selected boot image did not authenticate. Press enter to continue. When I do this it shuts itself down. I tried starting it in safe mode...
There are serious errors on you hdd and the system sees it as a hdd failure and consequetially it won't boot. Place your OS disc in the dvd drive, boot from it and choose repair.
Jul 28, 2014 | Computers & Internet
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
My acer 5232 will not boot up. The power is on and eventualy give a failure message suggesting to insert recovery disk. I do not have a recovery disk. It was taking a long time to boot before this...
Sounds like the disk drive has errors probably caused by a mechanical failure. You had a number of previous failures before this one and the disk is most likely unusable.
A local computer shop (not a big box store) MIGHT be able to recover your data but not your programs.
Hope this helps. I would appreciate your feed back.
Oct 01, 2011 | Computers & Internet
I have a HP Compaq nc 6230 which say 1781 HDD error and can not boot. i have done a BIOS test and everthing is fine but the problem keeps comming what can i do. pls help
HI rogerspie200 , actually problem is related to your Hard Disk Drive Bro not to BIOS and other hardware problem so please first of all check your Laptop Hard disk drive for whether it is working or not , if it is working then just format your pc
Jun 06, 2011 | HP Compaq nc6230 Notebook
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
Hi i forget my password bios hp nc6230 and the computer give me a message:Disk1 failure 1781 please you can help me?
Well... for the BIOS password, that's usually fairly easy. There is a jumper on most motherboards labeled CLRCMOS (some actually say CLR PASSword). Should be 3 pins, with a jumper set on 2 of them. move the jumper to the other side, press the power button. Nothing should happen, no fans or anything. then move the jumper back, and startup. Should clear out the password. As far as the disk failure- may have a bad hdd. download DFT, burn it, and run an advanced scan on your hard drive.
Apr 29, 2009 | Computers & Internet
No boot disk
when this error is showing give me details
mujahed@imsindia.co.in
Sep 27, 2008 | Acer Aspire 5315 Notebook
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
1781 Disk 1failure
Hi I have the same problem - when I turn on my compaq nc 6230 it says "1781 Disk 1failure ", I click enter button and it's starts to boot windows xp and works good without any poblems. I took the HDD out and install into different nc6230 and it works good and no any erro "1781 Disk 1 failure" at all - so it's NOT an HDD problem ! Can somebody help to troubleshoot ! Thanks.
May 17, 2008 | HP Compaq nx6110 PC Laptop
1780 disk 0 failure message
it's hard drive...most likely you are in need of a tune up.
check out this link, and you may find the Tuneup is just what you need.
Mar 17, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nc6230 Notebook Logo
1,490 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
