Question about Creative Labs Zen Micro MP3 Player
Malfunctioning mp3 player
When I swithed on my Creative Zen player, the player goes thorough the rebuilding library mode. After that it then locks ups in Firmware Problem mode. I have to remove the battery to cut it off.
    Brigadier General:
  • 6,966 Answers
Hi. am not sure if this would apply to your particular problem but you might want to check http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=185653. It might be of help or give you an idea on how to go about it. Good luck and regards.
Posted on Apr 12, 2007
My 8 gb zen is frozen
First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Mar 30, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Zen Xtra 40 GB
Ok this is what I have found.....Try to run the Recovery Mode here is a link to Creative Labs website that will walk you through it... Just look for Jukebox its on the bottom...you can get the firmware from the same website under support and then just select the type of jukebox you have....that will be the second link...You will need to click on Zen and then look on the right side for Archived Products
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=357,e=0000000000342903798,k=6058,sxi=1,varset=ws:http://us.creative.com,case=4794
http://support.creative.com/Products/product_list.aspx?catID=213&CatName=MP3+Players#
Good Luck and let me know if this helped
cbinny1
Aug 17, 2008 | Creative Labs Zen V MP3 Player
Mp3 stuck in rebuilding library mode
hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at oracle101rage@gmail.com if it works..Gud Luck guys
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Sleek Photo not rebuilding library
Read your manual or go to: http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Mar 31, 2008 | Creative Labs ZEN SLEEK MP3 Player
Rebuilding Library
Corrupt DB, firmware to reolve on creative website
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen Xtra 40 GB
http://us.creative.com/support/downloads/
and download the firmware for you version,.
Dec 26, 2007 | Creative Labs Zen V MP3 Player
Frozen
if it keeps on rebuilding the library the disk had a bad spot on it try going in to recover mode and do a clean if that doesn't work do a format if that doesn't work download the latest firmware if that doesn't fix you will need a new hard drive or flash drive.
Nov 15, 2007 | Creative Labs Zen Micro MP3 Player
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Micro MP3 Player Logo
71 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
