Question about Janome Memory Craft 9000 Computerized Sewing Machine
My bobbie want wind on my machine.
My bobbie want wind i have took it to the place where i got it to get it fix and when i got home it still was not fixed. what do i do now? when it windes now my thread is real loose on the bobbie. please help.
    Problem Solver:
  • 19 Answers
Hi there
sounds like you need to engage thread properly between thread guide then wind a few turns by hand place bobbin onto winder push to right foot control
should solve loose thread
mary h
Posted on Dec 29, 2008
I cannot wind the bobbin on my old Sears Kenmore 1802 Sewing machine. Help!
put bobbin place and loosen the hand wheel .on the right end of machine
Apr 09, 2015 | Kenmore Sewing Machines
I have a used Singer Starlet 496. The bobbin no longer winds. I took it for an estimate and was told that the winder had seized and they were unable to fix it. Can I do anything on my own?
Try Kroil; put in the places where metal rubs on metal. Or, you can try sewing machine oil. Place a drop of oil every place that metal rubs on metal, or, plastic on plastic. Let it sit a few days.
Jul 20, 2014 | Singer Sewing Machines
Winding bobbin athena 2000
I had one of these machines, they're Touch and Sew, and the bobbin winds in place. Check to make sure you actually have the correct bobbin inserted, because the bobbin it uses is available with a metal center post and without a center post, and yours takes the one without. I had another machine that took the center post one and accidentally put the wrong one in the 2000 one day and had the same problem.
Jul 10, 2014 | Singer Sewing Machines
Bobbin winder stopped working
The winder ring has most likely broken or come off. This part is not easily installed by a home user as the machine has to the taken apart to replace it.
Apr 03, 2014 | Brother SE-270D Computerized Sewing...
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Mar 13, 2011 | Sewing Machines
How do I disassemble a Brother sewing machine? I have it almost open but one part, below where you wind the bobbin, will not come apart. Part of a screw that holds a piece in place fell out while trying...
Disassemble your home sewing machine for routine maintenance Many sewing machine repairs can be made at home, and most repairs can be completely avoided through routine sewing machine maintenance. This tutorial shows you how to carefully disassemble your machine to give it a round of maintenance. You will need a screwdriver - make sure not to lose any of the screws! How to Disassemble your home sewing machine for routine maintenance
Oct 11, 2017 | Brother Sewing Machines
Sewing machine: Problem getting bobbin to automatically wind with thread from spool
You ought to have a 3 mth warantee with this used machine, take it back to the dealer and have them fix this problem...in Australia, consumer law provides that the sale of goods requires that they are "fit for their intended purpose".....there is almost certainly a similar provision where you are........get it remedied soon, as a feature that has not worked since you purchased ....perhaps calling first to ensure you are able to meet with the service person to explain.
I would not recommend you open it yourself until the dealer has looked at it.
If they cannot fix it, ask for replacement or money back.
Mar 08, 2008 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
120 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
