Question about Microsoft Xbox 360 Controller
Mi xbox360 controler lite suddenly started to glow by circling
Instead of one lite in one corner in the X in the controller it glows by circling but i have only 1 controller now what should i do.please reply.
  • Anonymous Dec 25, 2008
    I got a new xbox360 controller and when i turned in on it kept blinking.
  • Anonymous Dec 26, 2008
    my xbox controller wont connect it has four lights instead of one
Does it glow in all four quadrants and doesn't go to the player 1 quadrant? If it does, I think I just barely got past that problem! What you need to do is: Turn your controller on (make sure the 360 is on first) press the connect button on the console, then the most important part: HOLD THE CONNECT BUTTON ON THE CONTROLLER! This was a real biggy for me, i just tapped the button instead! hope i helped!
Posted on Dec 26, 2008
2006 chevy silverado duramax hd 4WD has codes u1016 /c0035/co201/po673/675/677 but runs great
DTC P0671: Cylinder #1 Glow Plug Control Circuit
DTC P0672: Cylinder #2 Glow Plug Control Circuit
DTC P0673: Cylinder #3 Glow Plug Control Circuit
DTC P0674: Cylinder #4 Glow Plug Control Circuit
DTC P0675: Cylinder #5 Glow Plug Control Circuit
DTC P0676: Cylinder #6 Glow Plug Control Circuit
DTC P0677: Cylinder #7 Glow Plug Control Circuit
DTC P0678: Cylinder #8 Glow Plug Control Circuit
Circuit/System Description
The glow plug controller has the ability to perform internal checks, an open or a short to ground on each of the glow plug circuits. If the glow plug controller senses a problem in a glow plug circuit, the glow plug on the affected cylinder will be disabled and the glow plug controller will send an error message to the engine control module (ECM). If this condition exists, the DTC will set.
Conditions for Setting the DTC
The glow plug controller detects that the glow plug control circuit is open, shorted to ground, or has more than 1 ohm of resistance.
Circuit/System Verification
Verify that DTC P064C is not set.
If DTC P064C is set, refer to DTC P064C.
Ignition ON, engine OFF, observe the scan tool Glow Plug 1-Glow Plug 8 parameters. All 8 Glow Plug parameters should closely match each other.
Refer to Testing for Intermittent Conditions and Poor Connections if you cannot duplicate the conditions.
Engine running, observe the DTC information with a scan tool. DTCs P0671-P0678 should not set.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
DTC C0035 Left Front Wheel Speed Sensor Circuit
DTC C0201 Antilock Brake System (ABS) Enable Relay Contact Circuit
The system relay, located within the electronic brake control module (EBCM), supplies battery voltage to all of the valve solenoids and to the ABS pump motor. When the relay contacts close, the EBCM monitors the voltage supplied to the valve solenoids and compares this voltage to monitored ignition voltage.
Jul 30, 2016 | Cars & Trucks
What is the code p0473 for a dodge sprinter van 2008
Error Code: P0404
Fault Location:
Exhaust Gas Recirculation (EGR) System - Range/Performance Problem
Causes:
-Hose leak/blockage.
-Wiring harness.
-Exhaust gas recirculation (EGR) valve/solenoid.
Error Code: P0473
Discription:
Exhaust Gas Pressure Sensor - High Input
Causes:
- Wiring short to positive.
- Exhaust gas pressure sensor (G450).
- Engine control module (ECM).
Error Code: P0674
Description:
Glow Plug Cylinder 4 Circuit - Circuit Malfunction
Causes:
-No Pre-Glow Period.
-Poor Cold Starting.
-Glow Plug Wiring faulty.
-Poor connection.
-Relay.
-Glow plug control module.
-Glow Plug faulty.
-Engine control module (ECM).
Solutions:
Check Glow Plug Wiring.
Check Glow Plug.
Error Code: P0675
Description:
Glow Plug Cylinder 5 Circuit - Circuit Malfunction
Causes:
-Poor connection.
-Relay.
-Glow Plug faulty.
Solutions:
-Check Glow Plug Wiring.
-Check Glow Plug.
Sep 20, 2014 | 2008 Dodge Sprinter
Code po670 what does it mean
- P0670 states there is a problem with the glow plug control module or glow plug(s)
- P0670 Glow Plug Mod Control Circuit
- Standard DTCs (ISO 15031-6/SAE J2012): Glow Plug Control Module Control Circuit/Open
Read more: http://mbworld.org/forums/diesel-forum/485795-2008-gl320-cdi-cel-p0670.html#ixzz33DhzVypf
May 30, 2014 | 2008 Mercedes-Benz Mercedes Benz Ml Class
10amp fuse for glow plug lite keeps on blowing
Maybe the glow plug relay is at fault?
Mar 11, 2014 | 2004 Opel Corsa 1.3
My 1992 diesel pajero which is import from japen, has problem with glow control unit, it not working, every morning it hard to start. i had replaced the control unit, it wan't help, does some one
You need to check that you are getting power to the glow plugs, when the light shows on the dash you should have 12V to the glow plugs, if you do have 12V at the glow plugs and it still is having issues starting then your glow plugs may need to be replaced. You can buy them off ebay at reasonable prices.
Mar 07, 2012 | Cars & Trucks
Will not start in morning. Have to use starting fluid. Will not start when key is in start position. Had to install push button direct to starter to turn engine over. Is this a glow plug problem and how...
MOST TIME GLOW PLUG CONTROLLER ON THE REAR OF INTAKE MANIFOLD CAUSES GLOW PLUG PROBLEMS.YOU HAVE TO USE 12 VOLTS TEST LIGHT TO SEE IF POWER GOING TO GLOW PLUG CONTROLLER.IF NOT YOU HAVE BLOWN FUSE OR FUSE LINK.IF POWER GOING TO GLOW PLUG CONTROLLER.THE CONTROLLER IS FAULTY OR THE ENGINE TEMPERATURE SWITCH IS BAD.
Oct 07, 2010 | 1990 Ford F350
I have a 1998 isuzu trooper 3.1td. The glow plug light on tha dashboard stays on for as much as 10 minutes sometimes. The local garage has tried to fix this with no success. Any ideas? Can I wire in a push...
If the glow plugs are faulty,this would be the reason for the problem,they are not glowing very well,unless the glow plugs have been replaced,then the circuit from the glow plug relay is faulty,or the relay itself,
Feb 05, 2010 | Isuzu Trooper Cars & Trucks
My 2004 f250 after it sits it wont start. the wait to start light only comes on for bout1 to 2 sec. the only way i start it is to plug it up at night what is my problem.
The wait to start light always comes on for at least 1 sec, if it goes off early it must think the engine is warm.
My guess is you have a faulty engine oil temp sensor that is telling the pcm that it is already warm. The only way to know for sure is to read the info with a scan tool.
Glow Plug System: Description and Operation
GLOW PLUG SYSTEM
The 6.0L diesel engine uses a glow plug system that preheats air in the combustion chamber to improve cold engine starting.
The system consists of:
- glow plugs.
- glow plug control module.
- powertrain control module (PCM).
- engine oil temperature (EOT) sensor.
- barometric pressure sensor (BARO sensor).
The glow plug monitor system is part of the On-Board Diagnostics II (OBD II) System.
The glow plug system is electronically controlled by the powertrain control module. If the oil temperature is below 55°C (131°F) the powertrain
control module will energize the glow plugs immediately after the key is placed in the ON position. Then, depending on the readings from the engine
oil temperature (EOT) sensor and the barometric pressure (BARO) sensor, the powertrain control module determines how long the glow plugs will be
on.
The glow plugs are located in the cylinder heads, under the glow plug buss bar.
The glow plugs are self-regulating. If the engine oil temperature is above 55°C (131°F), the powertrain control module will bulb-check the WAIT TO
START lamp but not energize the glow plug relay.
The glow plug ON time varies from 0-120 seconds depending on battery voltage, engine oil temperature and barometric pressure.
The glow plug control monitor (GPCM) system is designed to find failed glow plugs or failed wiring in the glow plug system.
Oct 30, 2009 | 2004 Ford F250
Glow plugs causing starting problem
if you need connectors and terminals for the glow plug connections under the valve cover, Ford sells then so you don't need a whole $600 harness.
info for your use
Section 03-07B: Glow Plug System 1996 F-250, F-350, F-Super Duty Equipped with 7.3L Diesel Engines Workshop Manual
DESCRIPTION AND OPERATION Glow Plug System The 7.3L diesel engine uses a glow plug system which preheats air in the combustion chamber to improve cold engine starting. The system consists of eight glow plugs, the glow plug control module (12B533), powertrain control module (PCM) (12A650), engine oil temperature (EOT) sensor and barometric pressure sensor (BARO sensor) (12A644). The glow plug system is electronically controlled by the powertrain control module. The powertrain control module energizes the glow plugs immediately after the key is placed in the ON position and then determines how long the glow plugs will be on according to the engine oil temperature and the barometric pressure. The required time for the glow plugs to be energized decreases as the engine oil temperature and barometric pressure increase. The glow plugs are self-regulating, and the powertrain control module controls relay ON time. The powertrain control module protects the glow plugs by energizing them for short durations if the battery voltage is abnormally high.
Possible Causes: Insufficient glow plug ON time will not allow enough heat to accumulate in the combustion chamber to easily facilitate starting. If the glow plug system ON time does not meet any of the specifications in the accompanying chart the problem is most likely a faulty wire harness connection, ground connections or glow plug relay.
If the glow plug resistance to ground is high, the most likely causes are an open UVC (under valve cover) harness or open glow plug.
Relay Operation
Install a DVOM on the glow plug feed side of the glow plug relay (large stud with two wires connected). Turn the ignition key to the ON position but do not attempt to start. Note the time in seconds from when the key is turned on and the glow plug relay energizes until the glow plug relay de-energizes. The glow plug relay makes a loud click noise which is easily heard when it energizes and de-energizes. The dome light will dim and the dash voltmeter will dip when the glow plugs are drawing current from the battery. Compare the times measured to the table (time will be affected by engine temperature, battery condition and vehicle altitude). The voltage at the glow plug feed terminal may vary from 9 to 12 volts depending upon battery condition.
If battery voltage not present check for B+ at power supply terminal (terminal with single large wire). Power for glow plug power supply is supplied from starter relay through two fusible links at solenoid.
Glow Plug Operation
Disconnect all of the glow plug/injector harness connectors from the valve cover gaskets. With the pigtail installed, measure glow plug resistance to ground (preferably B-). A resistance measurement of .1 to 6 ohms indicates a good glow plug.
Glow Plug Harness Continuity
Measure for continuity from the connector harness to the glow plug feed terminal on the glow plug relay. Resistance should be less than 5 ohms.
Incorrect measurements will result if all glow plug/injector connectors to valve cover are not disconnected.
Glow Plug Relay The glow plug relay (12A343) has a plastic base and two mounting bolts. It is operated by the powertrain control module (PCM) (12A650) which senses engine oil temperature, PCM voltage and barometric pressure. When the engine oil temperature or the barometric pressure is low, the PCM activates the glow plug relay and the glow plugs. If the PCM voltage is too high, the powertrain control module deactivates the glow plug relay and the glow plugs immediately energize for a shorter duration, decreasing the modulation of the duty cycle.
Glow Plug Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE RED-STRIPED WIRING HARNESS CARRIES 115V DC. SEVERE ELECTRICAL SHOCK MAY BE RECEIVED. DO NOT PIERCE.
    Remove valve cover (6582). Refer to Section 03-01D .
  1. Disconnect glow plug electrical connector using a pair of pliers.
  1. Remove glow plug using 10mm socket.
  1. Clean and inspect glow plug tip for damage. Replace if damaged.
Installation
  1. Install glow plug and tighten to 19 Nm (14 lb-ft).
  1. Connect glow plug electrical connector. Make sure glow plug wiring is routed to avoid moving parts.
Glow Plug Control Glow plugs are used to warm the cylinders to improve cold-engine starting. The PCM uses the engine oil temperature (EOT) sensor and barometric pressure (BARO) sensor to determine how long the glow plugs will be on. The PCM energizes the glow plugs longer if the engine is very cold or if the barometric pressure is low at high altitudes.
The PCM controls the relay that supplies power to the glow plugs with the glow plug control (GPC) signal. When the GPC signal is grounded by the PCM the relay closes, turning the glow plugs on.
The glow plugs are controlled by the following sequence:
  1. PCM energizes the glow plugs.
  1. The PCM energizes the glow plugs immediately after the ignition is placed in the ON position.
  1. The PCM then determines how long glow plugs will be on based on EOT sensor and the BARO sensor. The required time to warm up the cylinder decreases the engine oil temperature and barometric pressure increases at low altitudes.
Glow Plug Lamp Control The glow plug lamp (GPL) signal controls the WAIT TO START light located on the instrument panel. This light is used to indicate when to start the engine. The cylinders are being warmed by the glow plugs during and after this light is lit. The PCM energizes the glow plug lamp longer if the engine is very cold or if the barometric pressure is low.
When the GPL signal is brought low, the "Wait to Start" lamp is turned on.
The glow plug lamp is controlled by the following sequence:
  1. PCM lights the WAIT TO START light after a key on reset occurs.
The PCM determines the glow plug lamp activation time based on engine oil temperature, barometric pressure and battery voltage.
  1. PCM turns off the WAIT TO START light.
The glow plug lamp is turned off when the timer counts to the number of seconds specified by the PCM. The glow plugs will normally remain on longer than the "Wait to Start" lamp.
Mar 14, 2009 | 2004 Ford F350
Doesnt wnat to start (1989 7.3 diesel)
hey buddy,,, does ur 350 have a WAIT TO START LITE,,,turn key on a start lite should lite wait till this lite goes out before cranking,,,engine should crank over about 5-6 turns and it should fire up,,,if it don't start , turn key off then on, lite should come on,wait until u hear the solenoid start 2 click, turn key off ,turn on again, lite will lite ,wait till u hear the solenoids click, turn 2 start,if it doesn't start rite up turn key off, grab a test lite 12 v,[ check ur glow plugs,] test lite, place clamp end on positive post of battery ,pull wire off of the individual glow plug, put the point of the test lite on the glow plug that the wire was attached to, if u have no lite the glow plug is no good,if the lite is dim the plug is on the way out ,if the lite is bright the plug is good, move 2 all 8 glow plugs,if there is 1 bad 1 the rest will not function proper,if u r going 2 replace any of them make SURE that they r the rite 1's cause there is 2 types[ don't let the parts guy tell u different[the wire end should not have 2 b altered 2 get it 2 plug on 2 the glow plug,take a sample if u need 2 replace,check the wire end that they r the same,,, tighten snug don't over do it, go through the steps above 2 start, should fire rite up , if it doesn't and u don't hear the solenoids click the controller is the next step, u should have 12 v at the + on ur controller,,, if not ur wiring 2 the controller is out[ fuse; wiring, ignition switch maybe at fault,if 12 v at the controller try the test lite at the glow plug terminal if this functions ur in good shape here,,,2 check and c if u have a lack of fuel[READ AND DO REAL CAREFULL]remove top of air cleaner,,a very short spurt of ether,,, 2 START,,turn the key rite over 2 start[don't activate the glow plugs as the ether may burn the tips off the glow plugs] should start immediately and stay running,,if it stalls,, try same again,,if it stalls again there is a fuel problem,,,check all lines and fittens,,check the mechanical lift pump,,, filters tight ,, bleed system,, remember those starters on these animals cost a p pot full of money so easy on the cranking time [easy on the tantrums keep asking questions and soneone will get u there,,, hope this gives u the help u need Len
Jun 26, 2008 | 1989 Ford F 350
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
