Question about Acer Aspire 3610 Notebook
Acer arcade when im recording from my acer arcade program i cant seem to hear anything i am sayn tho my visual is working my audio isnt...but i can hear everything else my recording isnt working
I am trying to get my parents Skyped up! They have an old'ish Emachine m5 118 g1. I skyped them and visually eveything works great both ends. Audio wise - They can hear me, but I can't hear them. Any...
My first thought would be to make sure the headset is working with another application. Go to Start-All Programs-Accessories-Entertainment-Sound Recorder and see if you can record anything.
Then check the Skype Audio settings:
- Is the correct microphone chosen?
- Turn off "Automatically adjust microphone settings" - that is most likely the culprit if the hardware is ok.
- call "echo123" from Skpye and do a test recording.
Also - I assume your headset is working.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 03, 2010 | E-Machines eMachines Desktop PC
Webcam Problems
This is a known issue and this should help you. It's hard to tell you what to do when you don't give model # or the OS your running. XP,Vista,7,....?
Jan 28, 2010 | Acer Computers & Internet
Problem in audio jack
double click the volume icon in the system tray next to your clock. click Options > Properties make sure that the microphone is ticked then OK the microphone option is now added to your volume controls make sure it isnt muted and turn it up. Repeat this for the recording option when in properties.
Hope this helps Please Rate!
Nov 27, 2009 | Acer Aspire 4315 Notebook
How do i record videos with my acer aspire 5735Z webcam. It only takes pictures, and I can't seem to find out how to make it do a recording. audio recording works fine on an indepent program.
The Acer Arcade software will envoke many options that you can record with your acer crystal eye webcam. The software is preloaded and its just off the start menu under acer software.
I hope this helps
or you can use windows movie maker and activate your webcam in there if you so choose. Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 29, 2009 | Acer Aspire One PC Notebook
ACER ARCADE VIDEO CAM
Please explain what you mean by cannot playback recorded clip. Is it in an unknown format or you can find where the recording is being stored?
May 26, 2009 | Acer Aspire One PC Notebook
Audio - microphone problem(Other users cant hear me)
Maybe its not you that got the problem, but the other user.
Apr 11, 2009 | Acer Extensa 4620 Notebook
VERY SLOW..AND some internet not working!
One of the first things to do is download a program called "Malware Bytes" (Google it). Install and run the scanner/cleaner to wipe any nasties off of the machine. You may find that after running this program many of the woes you've described magically go away (especially the slow operation)...
Feb 19, 2009 | Acer Aspire 3610 Notebook
How do i operate my acer crystal eye on acer 4710 notebook
I can't verify this, but it's worth a shot:
Go into Acer Arcade or Acer Arcade Deluxe OR go into Windows MediaCenter and then select Acer Arcade. Once in Acer Arcade there should bea program called DV Wizard. Once in DV Wizard select Acer Crystal EyeWebcam and the rest is obvious. Once you are done and click stoprecording, the video that you recorded will be in your Videos folder.
Source
Jan 03, 2009 | Acer Aspire 3610 Notebook
Blue Ray Software
Just do recovery your notebook. try to run the acer Arcade without upgrade it. I also have some problem when I upgrade/ update my Acer Arcade to latest Version. I'm using Aspire 6920G.
Jul 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3610 Notebook Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
