Question about D-Link DIR-625 (790069292637) Wireless Router
I have did the steps and i still can't get on line
I did want the computer told me to do and i still can't get on line so want am i to do
    Scholar:
  • 97 Answers
This is a wireless "N" Router. that means it requires a "n" version adaptor in your computer too.
I assume you cannot connect at all at this point.
Unless you have the latest in PC's your not likley to have the N version installed. Unless you got the card as well at time of purchase.
Thats OK though as this router can also handle the other types of wireless connections too. You need to go to the router setup software and enable the B and G versions of wireless and you should see the router then. Disable the N features and see what happens.
Posted on Dec 24, 2008
I was told by our Satellite Service to "secure"
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin (F5D5231-4) Router
Sansa e280 (8GB) load image failed how to repair it
The help page for this problem is here:
http://kb.sandisk.com/app/answers/detail/a_id/25
Just reset the player only, as told in step 1. Start step 1, when the player is NOT connected to a computer.
If that helps, no further service required.
Else continue as told in the overview, step 2 and 3.
  • Start step 2 with the player switched OFF and NOT connected to a computer. If the player is frozen, first press and hold the power button for about 30 seconds to switch it OFF.
  • Next go to the link next to step 3: how to download and update the firmware
Oct 05, 2010 | SanDisk Sansa E280 MP3 Player
Can't get wnce2001 netgear adapter to work. Also have netgear wnr2000 router. Push and connect, I do have all green lights, but samsung tv states service is unavailable due to network interference.
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable up to computer. Proceeded to the netgear wizard to reconnect adapter to network. Got as for as step 3 and then told that there is difficulty connecting to the existing network. Does anyone have any suggestions to help solve my current problem? How can I reconnect?
Oct 04, 2010 | NetGear Computers & Internet
Location of fuel filter,its boggs down when applying gas to speed up,was told fuel filter is clogged but i cant find it
Open the gas door and remove the gas cap. This will help to alleviate the pressure in the fuel line.
  • Step 2 Crawl under the Bravado and trace the fuel line from the fuel tank. The filter is an in-line filter and attached to the fuel line.
  • Step 3 Unsnap the fuel inlet line from the filter. The filter is equipped with a quick-connect fitting that can be unsnapped and pulled off the piping of the filter.
  • Step 4 Remove the outlet line off the piping of the filter. This line can removed the same as the inlet line.
  • Step 5 Unbolt the mounting bracket holding the filter in place with a socket wrench. The bracket is held in place by one bolt.
    Replacing the Fuel Filter
  • Step 1 Attach the new fuel filter to the mounting bracket and secure it to the frame. Tighten the bracket snugly with the socket wrench. Ensure the arrow on the filter is facing toward the front of the vehicle. The arrow indicates fuel flow direction.
  • Step 2 Snap the inlet line on the filter. Push the line on to the piping of the filter till it clicks in place.
  • Step 3 Connect the outlet line on the filter. This line will snap in place as well.
  • Step 4 Screw the gas cap back on to the fuel door. Close the gas door.
  • Step 5 Crank up the SUV and let it idle. Ensure there is no hesitation or stalling
  • Jun 05, 2010 | 1996 Oldsmobile Bravada
    There is to much gas pressure on the fuel pump so when it doesn't crank we get a screw driver an release the gas then it will crank what is the cheapest thing that we can do instead of getting gas all over...
    The computer is supposed to monitor fuel pressure on the fuel rails, so either you have a bad sensor, or the computer thinks it's releasing the excess pressure. There is either a servo (which is a fancy word for "something which does what it's told to do when it's told do it") that the computer operates to release the pressure, or you may have a clogged fuel return orifice, return fuel line, or vapor canister/line.
    Feb 16, 2010 | 1994 Dodge Dakota Club Cab
    Power brakes not working
    No such thing as vacuum lines to the master cylinder. You do have a vacuum line on the brake booster (power assist). When you step on the pedal do you hear a whoosing sound down by your pedal. This is a leaking Booster. Needs replacement.
    When you step on the brake does the engine rpm change. This is a leaking check valve (one way air valve).
    Jul 17, 2009 | 1996 GMC Sonoma
    1997 Nissan Max. Steps to get computer to read again after reset.
    the sequence is listed on pg.9-19 and 9-20 of the owners manual
    Jan 13, 2009 | 1997 Nissan Maxima
    I had a long chat session yesterday. I was told how to fix my printer. Step one was to disconnect the printer from the computer. Step two was to restart the computer. Step 3 was to run the install CD...
    STOP.disconect the printer.remove all drivers associated with the printer.reboot computer.go to printer web site and download updated drivers.reboot.Hook computer back up.Reboot.when computer boots back up it should recognize the printer.it should then install your drivers If not go into control panel..."add new printer".follow the prompts. this should solve all problems but if not i am here to help further.RICHARDM69
    Dec 07, 2008 | Office Equipment & Supplies
    I can't get on line
    A blinking DSL light means that you have no DSL sync -- you are not receiving a digital signal. You will need to contact your ISP to have them repair your service.
    Steps to do first:
    1. Powercycle the modem -- unplug the power from the back for 15 secs, plug it back up.
    2. Ensure that all phones that share a line with the DSL have filters attached.
    Jan 28, 2008 | Westell Wirespeed LiteLine 6100...
    D-Link DIR-625 (790069292637) Wireless Router Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
