Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes wont turn on shampooer
Yesterday I used upholstery tool for first time/now want to clean carpet and brushes wont turn. Have cleaned filter and turned brush switch off and on but no luck Help!!!
  • 752 Answers
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Posted on Dec 25, 2008
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes wont spin on my Hoover rug shampooer Model # f7220-950.
try cleaning brush...
if sam problem need replaced turbine part no: 43191009 Turbine & Gear Assem
Nov 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not turning
your belt could be turn of or it is jamed inside ,take of the buttome and check for those two things.if my info was of any help to you please leave a comment ,thankyou.
Sep 02, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
175 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
