Question about Philips 51PP9303H Rear Projection Television
No sound no picture
I BOUGHT THIS TV KWNOWING THAT IT WASN'T WORKING (NO SOUND NO PICTURE) BUT WHEN I BRING IT HOME I CONECTED AN ANTENNA AND I WAS ABLE TO SEE SOME FREE CHANNELS AND WHEN I PUT THE VOLUME UP TO 99 I COULD HERE THE SOUND VERY LOW BUT NOW THE TV HAS NO PICTURE AGAIN NO SOUND AND WHEN I TRY TO TURN IT ON THE ON BUTTON BLINKS 9 TIMES AND THATS ALL IT DOES. PLEASE HELP!!!!!
    Genius:
  • 1,074 Answers
Have a tech check your tv it needs to be repaired the tv could have some cold solder in the diffrent circuits.if noytthen it will need a complete repair.
Posted on Apr 14, 2007
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
Why do the stations keep blinking in and out all day and all night? is this how it's going to be even after 6-12-09? it really gets on my nerves when i'm watching tv and miss over half of whats going on or...
The channels are going off because the signal is not stavying strong enough to keep a regular picture. If you are having this with several channels, there are several things you can check. First, make sure all the antenna wires are not loose. Then find the signal strength option in your converter box (each is different thus you need to check the manual on how to use) to see how strong your signal is. If all channels are low, you most likely need a outdoor antenna. These can be bought at any home improvement store. There is no such thing as a digital antenna. The signal for the channels are still being sent over the same tv spectrum (most will be over UHF) thus walk away from any electronic store that is selling a special digital antenna, there is no such thing. I am using a outdoor antenna, and the picture I receive is just as good as cable. It is some effort to hook it up correctly but the improved picture is well worth the effort. Very heavy rain, wind and clouds at your home and near were the tv broadcast antenna is will also effect your picture. These problems go away as the weather gets better. Directv also has the same problems with weather.
Jun 05, 2009 | Insignia Digital-to-Analog Converter for...
We just converted our analog and get a bad picture
I would think it is wise to try another converter box. That is the only way to know for sure. There is also a possiblity that the reception where you are located is very poor.
Jerry G.
Feb 09, 2009 | Insignia Digital-to-Analog Converter for...
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Audi but no picture when cable box conected through DAV-X1
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Dec 25, 2007 | Sony DAV-X1 System
Mitsubishi 55809
Check the cabel TV or antenna conection first. And check the tv with a DVD player or VCR too if work thats a problem.
Some TV forget the settings after a power lost, so try to set the stations again.
Nov 11, 2007 | Mitsubishi VS-5043 50" Rear Projection...
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
RCA 35" Home Theatre
You have diagnossed the problem by moving the antenna imput,the problem might be a loose conection in the tuner itself,the grounds ussually get loose and need to be resoldered,if you are familiar with tv service you can resolder all the pins and grounds,there is another possibilty and that is the conector itself where the antenna screws is loose and it has broken the solder conection inside the tuner and the will have to be taken apart and resolder,the conector has to be solid .You have an option and is using the aux,1 or 2 and coneting you vcr to either one those imputs then you will need to change the channels thru the vcr,this way you will not have to worry about the tuner.Let Us know how it goes or if you need more information.
Oct 30, 2006 | RCA 27F530T 27" TV
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all Philips 51PP9303H Rear Projection Television Questions
Televison & Video Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
