I want to done b.e part time in cusrow wadia institute in pune after dme. what i can?
    Sergeant:
  • 306 Answers
Rani, this is a tech repair site not a bulletin board. Here is your application but please tell your friends that this is not what this site is for: http://www.wihg.res.in/vacancies/postform-jrf.pdf Merry Christmas, Steve Medley
Posted on Dec 24, 2008
  • Stephen Medley
    Stephen Medley Dec 25, 2008
    Yuo can still leave a FixYa rating if that helped you:) Steve
What is the minimum amount of downpayment required to buy a flat in Pune?
\The minimum down payment required to purchase an apartment in Pune varies from one financial institution to another. In usual cases, it depends on the LTV (loan-to-value) ratio that is followed by the financial institution in question. This is basically the maximum amount that the financial institution can sanction to the individual with the remainder being the down payment. This is usually the following:
  • 90% in case of home loans up to Rs.30 lakhs
  • 80% in case of home loans between Rs.30-75 lakhs
  • 75% in case of home loans exceeding Rs.75 lakhs
As a result, on an average down payment will range between 10-25% depending on your eligibility, monthly income, home loan amount and other factors. You should always check your home loan eligibility first. The eligibility criteria for Home Loan in Pune or other major cities of India vary from one financial institution to another. You need to compare them and select the best one which suits your needs.
Sep 25, 2017 | Finance
Bose 901's
yes u can use a KT88 tube amp , or BTW-2 amp for this da mc34a..this will work good, and you can buy this in e bay that would be cheaper.
You may also want to look at http://www.cattylink.com.
Dec 08, 2007 | Bose 901 VI Main / Stereo Speaker
I wanna to learn java and oop programming
Writing code is a skill that needs to be developed like any other craft. Start simple, and do it. Watching other people writing code isn't enough. Adjusting other peoples' code isn't enough. You have to write your own code, that solves your own logistical problems. They can be made up problems, but the practice of problem solving is the fundamental basis of coding.
core java training in chennai Best Core Java Training in Chennai Core Java Online Training
Sep 03, 2011 | Computers & Internet
Fault code 131 and 132 on bmw e46
EGR valve (Incorrect signal)
131 CAN time out (instr
2)
Input binary
stream bit data (0-
12V)
CAN message between DME/EGS
not received within expected time.
132 CAN time out (instr
3)
Input binary
stream bit data (0-
12V)
Nov 26, 2010 | BMW 323 Cars & Trucks
Engine code 171
Ensure there are no wiring faults from the Digital Motor Electronics (DME) to the throttle motor using a break out box.
If the wiring is not faulty then replace the throttle motor, then clear the DME adaptation values.
Switch off the ignition for approx 30 seconds.
Turn on ignition and delete DME adaptations and fault code memory.
Push down on the accelerator pedal four times to wide open throttle.
Aug 04, 2010 | 1999 BMW 318 ti
CHECK ENGINE LIGHT ON, WHAT IS DME CONTROL MODULE
Digital Motor Electronics (DME) is a microprocessor-based system that controls the ignition, the fuel injection, the oxygen sensor and numerous ancillary functions. DME provides raw data to an on-board computer that uses an alphanumeric display to provide you with information such as the average fuel consumption, the distance you can still cover with fuel in the tank, an average speed, outside temperature and more.
In the industry, DME is often referred to as the Engine Control Unit (ECU), under the heading of Electronic Engine Management Systems.
DME operates by continually monitoring such factors as engine temperature, speed, intake airflow, exhaust gas composition, and even the altitude. DME then literally fine-tunes the engine hundreds of times a second to provide maximum performance and efficiency. DME has a fail-safe program in the event of certain electrical faults. Current DME versions also have on-board diagnostics (OBD).
The 1998 Boxster location is in the rear trunk space on the left side on the firewall under the carpet.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 18, 2009 | 1998 Porsche Boxster
User Manual of GPS Shipmate RS 5700
My institute has GPS Shipmate RS 5700. Unfortunately, the user's manual for the same is not available. Can you please send us the same? If yes, please send me the softcopy at sozdemir@kirancom.trOR serkanrealdemir@yahoo.com If you don't mind, send the same at all.
Thanking you in anticipation.
With best regards,
Oct 12, 2007 | GPS
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
