Question about Sony STR-DG510 Receiver
STG DR510 no sound on left front channel
I've tried switching the speaker to eliminate a dead speaker and everything.  I can't sem to get sound out of the front left surround channel.  The wires are all fine, polarity is correct, I got nothin'.  PLEASE help it's driving me nuts.
    Brigadier General:
  • 8,546 Answers
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Posted on Apr 03, 2009
NAD 3130 one channel stopped working, tip what to do first?
May not be serious,first with good channel playing move all controls and switches on the amp,Dead spots can occur on controls especially if they are rarely used.balance controls,tape monitor switches etc so work them all.If fault doesn't clear try headphones,switched sockets can cause problems.next swap input signal leads,left to right. and if still no good try swapping over speakers left to right.STILL no sound? its the amp.Time for tools and a test meter.You can look for blown fuses but its never a good idea to replace a blown fuse without testing the circuit first.may cause further damage and put up the repair cost
Jun 04, 2014 | NAD Audio Players & Recorders
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
No sound from front left channel
Try swapping the connectors for front-left and front-right (just swap right at the back of the amp)
After the swap, does the front-left speaker work, and now the front-right is dead? If so, then it's a problem in the amp.
If not, then the problem is in the wiring and/or the front-left speaker itself.
Post back here with your findings, and we'll troubleshoot whichever part of the system is broken.
Apr 08, 2010 | Onkyo TX-SR605 Receiver
No sound out of front left speaker
front left channel power amp needs rpair
Jul 08, 2009 | Sony STR-DG510 Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Sony STR-DG510 Receiver Logo
284 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
