Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD is wired to the VCR and does not work
DVD player is wired to the VCR, then to the Sony Bravia. I ususally put the DVD in the machine, turn on the VCR and it all works. Someone messed with the TV remote, now the DVD player is working but does not play on the TV screen. I plugged in another DVD player and get the same problem so it's not the DVD but problem is with the TV remote setting. Can't figure out which buttons to push to get the DVD to show on the TV.
hspirit853@comcast.net hope you can help. Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, on the Sony Bravia, it should be set to either Channel 3 or AV, Video 1 or Video.
Should this be not corrective, pls post back how the VCR is hooked up to the Sony Bravia, specifically, how many cables and what colors are used.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 24, 2008
    Novelist:
  • 124 Answers
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
DVD and VHS don't work
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Mar 09, 2014 | Sony BRAVIA KDL-46W3000 Television
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
How do I re-connect a VCR/DVD player to a Bravia? I have (!) video output and (1) audio output wire from the VCR unit and have tried a number of combinations without success connecting to the back of the...
The DVD/VCR player should have video (Y) plus right (R) and left (?) outputs that connect to corresponding inputs on the rear of the Bravia TV. You should be able to press the TV/VCR button on the remote to select that device as the input source.
Mar 17, 2017 | Sony BRAVIA KDL-20S3000 20 in. LCD TV
My sony dvd slv-300p blue light progressive scan light is on and i cant do anything ?
my sony dvd vcr combo has a progressive scan flashing light when plugged in. i put a vcr in and now it's stuck. none of the buttons seem to be working. it is making a clicking sound inside on machine. how can i get this thing to work again?
Jan 23, 2011 | Sony SLV-D300P DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
I have a Bravia. None of the set up diagrams show a setup with a
I went where I made the purchase. It turned me off when I would have to pay you for the information that should have come with the instruction booklet. Bob
Jun 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Can't receive proper dvd/vcr signal
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
May 14, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
227 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
