Question about Microsoft IntelliMouse
IntelliMouse Setting Reset Everyday
I have a Microsoft IntelliMouse that is plugged into my HP Pavillion tx2000 laptop.. The cursor moves around the screen too slowly for my taste, so I reset the settings under the "Synaptics Pointing Device" icon on my toolbar... the problem is, I have to change the settings EVERY time my computer restarts. It won't hold the settings that I want. It's been happening since I got the new computer.. any advice?
  • dlkw999 Apr 18, 2009
    I'm having the exact same problem!! If anyone has a solution I would be so thankful.
  • fmr888 May 11, 2010
    go to mouse in control panel and set the speed of your mouse. this should save the setting for you
4 Suggested Answers
bluenadas
  • 203 Answers
SOURCE: unable to connect to the synaptics pointing device driver
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign. If synaptics is listed right click and select Uninstall. After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Posted on Jun 09, 2007
yooperbud
  • 8637 Answers
I am assuming that the mouse has batteries installed in it and the CD was used to install the software program for the mouse.
Did you try Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 19, 2009
  • 2567 Answers
SOURCE: inspiron 1520
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is disabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
If the above does not work, then you might consider carefully opening your laptop and disconnecting the touchpad. Most laptops will run fine without it. However, beware that since all laptops are very different it might even then not be easy or possible to disconnect just the touchpad; it's possible that it's an integral part of the keyboard assembly, which means that you will be practically disconnecting both the touchpad & the keyboard.
If this either did not work, then you might consider replacing your touchpad (and/or) keyboard.
Posted on Sep 12, 2009
Hp pavillion tx2000 entertainment notebook pc. initial o/s vista home premium. Problem with cursor drags automatically. whole system scan with kaspersky antivirus. problem not solved. o/s changed to...
You meant the built in mouse pad fails.
why not use wired USB mouse, now, and end the pain ,
then with a working mouse , get the HP driver from HP
and install it from HP. for W7. (luck)
at HP, fixyah is not HP, not at all..
that will work, if not driver issue, then buy a new pad. oops none are sold new.
after 10 years. so that leaves what, used pads sold on ebay..'
HP dot com. your support page. (seems to be collapsing from age)10years old it does. by hp rules.
even the tx2500 series is 10 years old now.
https://support.hp.com/us-en/product/HP-Pavilion-tx2000-Entertainment-Notebook-PC-series/3650975
does your service tag show tx2000 , that is series
not telling the service tag number gets you wrong facts.
wrong drivers, so next time show the full model
try the support assistant there.?
here are the full list of tx2000 series PC
see ,its not just one PC, we need the full model p/n to answer
with any accuracy at all.
http://partsurfer.hp.com/WSearch.aspx?Wchar=Y&searchText=tx2000#
there is no guarantee at all any w7 driver exist. for your mouse pad but many times the Vista version will work
you lost that now, i you dont have the install disks from HP.
or the pad is simply bad.
we have tools here to scan your pad chips to see the makers
name and then get driver from them direct. after HP drops support.
Jan 24, 2018 | HP Pavilion TX2000Z Notebook
Hp pavillion tx 2000 drivers
Below is the link where you can download the drivers for HP TX2000.
Click Here to download the drivers.
Please let me know if you have any further questions or concerns.
Thanks.
May 02, 2010 | HP Computers & Internet
Hp pavillion tx2000 all lights are on - hard
That's a very common issue with that model, You will have to reflow the GPU with a heatgun. You can find more info from http://www.msbin.com if needed.
Oct 15, 2009 | HP Pavilion dv6000z Notebook
Need to find a spare T key
http://tech.yahoo.com/blogs/null/143392#see_comments
lok at this.
May 27, 2009 | HP Pavilion TX2000Z Notebook
My Microsoft Intellimouse Trackball rolls but the cursor doesn't
the circular disk that surrounds the trackball and has a little raised part can be turned to left - take it off and ball will fall out- inside are 2 tiny black rubber wheels one to left and one south of that- clean with alcohol on a cloth 9 not soaked) - I scrap them with my nail going across & you'll see gunk come off. Slso turn it upside down & tap it so all dirt inside falls out. wipe all around inside with cloth. Then clean the circle that holds ball. It has to have no dirt on inside area. Clean & dry ball- put back together and make sure to turn the circlular disc till it points to the dot on top. If that gets turned just a little off center it will cause ball to go all over. I've had mine for years & won't part with it. Can't stand chasing a regular mouse around the desk.
May 07, 2009 | Microsoft IntelliMouse Trackball 1.0
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
Dell ms intellimouse vertical movement of cursor
open the mouse remove the ball you should see two support shaft for the ball check whether they are rotating clean them if you can
if they rubber shield of shaft is damaged try replacing them with valve tube you usually use in a bycycle tyre
clean the transistors standing near the shaft flywheel using a soft cloth
it will be fine
Dec 14, 2007 | Dell Microsoft Intellimouse
Wireless Intellimouse Explorer 2.0 problem
DEAR, Once again install fresh driver of your mouse
Sep 25, 2007 | Microsoft Wireless IntelliMouse Explorer
Microsoft IntelliMouse Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
