Question about Samsung DLP HL-P5663W 56" TV
1080p to 1080i
I had a 73' TV that was1080p. Well I got a brand new DLP that is 1080i. My settings on the PS3 are set to 1080p. How do i set them to 1080i if I can't see the screen?
1st - turn off your ps3.
2nd - push the power-button and keep pushing it until you hear some beeping sounds.
now your ps3 resolution has been reset :)
Posted on Jan 07, 2009
  • 4 Answers
Use the original composite (yellow, red, white) cable that came with the PS3 and connect to a composite input on the TV. This way you can see the setting for the PS3 and make your changes. Hope this helps
Posted on Dec 26, 2008
2 Suggested Answers
  • 4 Answers
SOURCE: I had a 73' TV
Use the original composite (yellow, red, white) cable that came with the PS3 and connect to a composite input on the TV. This way you can see the setting for the PS3 and make your changes. Hope this helps.
Posted on Dec 27, 2008
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Mode Not Supported
Set the PS3 to 1080i for your HL-P5663W. I verified the owners manual and this TV does not support 1080p even by PC input.
Mar 14, 2010 | Samsung DLP HL-P5663W 56" TV
I bought a PS3 and the best resolution I can get is 1080i. How do I get 1080p?
Purchase a can of comet cleaner, you have to polish your screen to a high luster. Remember the karate kid, wax, wax off.
Sep 19, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
"Invalid format" how do I change from 1080p to 1080i or 720i?
I had a second playstation hooked to another tv in my home and took a controller from the non-LG-TV-displaying ps3 and one from a working ps3 on a seperate TV. And used the working ps3 to guide me to the settings menu on the ps3 that was not displaying video. Anyways, if you cannot see the tv screen because it is set on 1080p and your LG will not display it (Only displays up to 1080i). Start The PS3 and press the D-pad buttons in this order.
Left 10+ times. (This Takes you to the far left icon in the XMB)
Right Once. (This is the settings icon)
Down 20+ times. (To reach the bottom of the settings)
Then Up 4 times (This is Display Settings)
Press "X" Once. (This enters Display Settings)
Press Up 5 times (This Makes Sure you are at the top of the sub-menu at Video Output Settings)
Press "X" Once (This Enters Video Output Settings)
Before pressing any more buttons, Know what cables you have pluged into your TV.
For HDMI Just Press "X" and it will auto adjust to for the new TV.
For Component / D-Terminal Output Press Down Once Then "X", and X Again (This changed my ps3 from the 1080p-Invalid Format back to 1080i and fixed my problem.
For Composite Video Output Press Down Twice, Then "X" and X again.
For AV MULTI / SCART Output Press Down Three Times, Then "X"and X again.
Apr 26, 2009 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
My 42LG50 won't accept the 1080p output from my PS3 Plz help.
Most PS3 games do not support 1080p, so if u have a 1080p supporting game, only then can u do it.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Dec 24, 2008 | Samsung DLP HL-P5663W 56" TV
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Samsung DLP HL-P5663W 56" TV Logo
141 people viewed this question
Jerry Greenberg
Jerry Greenberg
