Back to:
Tags:
eVision EC720E 20 in. TV/VCR/DVD Combo
My TV turns off by itself. How do I correct this? (by 4 users)
By kcw573 - usenet poster
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Sep 19, 2008
had my tv almost 1 yr worked fine yesterday but now shuts off after 3 min i turn it back on and it does it again and again won't stay on
Comment by TMsFit, posted on Mar 02, 2008
Turns off after about 30 secs...it started yesterday and cant seem to work no matter what I do
Comment by Bajatonga, posted on Feb 25, 2008
turns off by itself and then have to wait 30-45 seconds before it allows me to turn it on....15-or so minutes later...same thing happens...
Best Solution
posted on Aug 08, 2005
Thanks for Trying (70)
Lizzy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. If this does not correct the problem, you may need to have your TV serviced.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My TV turns off by itself. How do I correct this?:
I don't want to Accept this solution
Solution #2
posted on May 09, 2008
Not Rated (0)
Dan-DBS
Rank:Master Master
Rating: 85%, 9 votes
It wouldn't do any good to try and have it serviced if there is a problem, BECAUSE, if you open it up you'll see it's made bu Orion, Wal-Marts cheapest brand and they don't support parts for this throw-away. The only thing Toshiba on this set is the name. Goes for Toshiba's up to 27" and some 32" sets.
Thank You!
Solution #3
posted on Apr 30, 2008
Not Rated (0)
RossBallard
Rating: 0%, 0 votes
Ah, had the same problem with my 27" combo. I called the tech. He reached into the VCR slot and took out a forgotten tape that was causing the problem. Sometimes they get wedged a little crooked and won't come out with the Eject button. Take out the tape, get rid of the premature shut off.
Ross...
Thank You!
Solution #4
posted on Sep 15, 2007
Not Rated (0)
ComposerDan
Rating: 0%, 0 votes
Ok, I just had the same problem for the second time. Hope this solution will help you. Way back months ago we put a VCR cleaner in the drive and that fixed it. We don't have one of those right now so I just put a regular tape in and it didn't want to take it at first, I held it in there and then let it come out and now the TV realizes that there is no tape in it so it doesn't turn off anymore. I have now taken a piece of clear packing tape and covered over the door to the VCR so that nobody will try to use it anymore. The problem is that the TV thought there was a tape in and that the tape was at the end of the reel so it wants to shut the TV down. I hope this helps you and would love to hear from you if it did. taylor777@verizon.net
Good luck with fixing it. Mine is still on as I type so it looks like a success.
Thank You!
Solution #5
posted on Dec 05, 2005
Not Rated (0)
TANTO
Rating: 97%, 3 votes
CHECK SLEEP MODE FUNCTION, FIRST.
Thank You!
Can you Help with these TV Combos problems?
TV Combos
my tv comes on the only thing that it will do is samsung...
TV Combos
I need the code to program the remote control so that it...
TV Combos
remote control code
the set turn's off after 30-40 min's, does'nt matter if...
I have a combination Sylvania VCR/DVD recorder. I dubbed...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
