Sync Treo to Blackberry
My palm Treo 680 wont sync all my data to my new Blackberry Bold. I used the blackberry Device manager and almost all the records go accross but it then stops with 100 records not export.Can you please help.Tim
natas123
  • 46 Answers
SOURCE: Treo vs. Blackberry; Palm OS vs. windows OS
I would go towardsa ablackberry and not a treo. Blackberry is the future.
Posted on Feb 11, 2008
cropp
  • 377 Answers
SOURCE: my palm treo 680 turns itself off repeatedly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Posted on Mar 26, 2008
SOURCE: Blackberry Curve & Outlook 2007
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Posted on Jun 15, 2008
quakefiend
  • 15 Answers
SOURCE: USB Device Not Recognized for Palm Treo 680
if you are using Vista ultimate, it is a 64 bit operating system and therefore palm doesn't have official support for it yet, but someone has found a solution:
http://forums.palm.com/palm/board/message?board.id=windows_hotsync&thread.id=17980
Posted on Jul 19, 2008
SOURCE: use wifi in palm treo 680
WiFi is not supported in the 680. I understand that the Centro and the new 800W have it. (Me, I'll wait for the 800p before I trade in my trusty 680.)
Posted on Jul 23, 2008
MY BLACKBERRY FROZE with a white screen and reads reload data 513
All you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. Unfortunatly you will lose all data on the phone because you will be re-installing the software. If that doesnt resolve the issue then, this is a device issue. You will need to contact your service provider for replacement options!
Mar 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
How do i reload software 513 on blackberry bold 9000 or where and much will i be charged
All you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. Unfortunatly you will lose all data on the phone because you will be re-installing the software. If this doesnt resolve the issue then, this is a device issue. You will need to contact your service provider for replacement options!
Blackberry Bold 9700 - RELOAD SOFTWARE 513
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
Feb 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
Jum error 102 on new blackberry bold phone is frozen with white screen and message 'jum error 102'
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 14, 2010 | RIM BlackBerry Bold Smartphone
I need to unblock my 8900 i found, i get signal but can't make calls.. please help me use it...
Jan 12, 2010 | RIM BlackBerry Bold 9000 Smartphone
Can you sync the palm calender to a blackberry 8330
if you tell the palm hotsync program to sync with outlook, you can dump your calendar into outlook, and when you sync your blackberry with the desktop manager you can tell it to sync with outlook as well, and that is how you can transfer the calendars.
Nov 05, 2009 | Palm Treo 700p Smartphone
Want to wirless syn with a calendar & contact list for back up. what is the best program to use????
You can use the BlackBerry Desktop Manager to synchronize your organizer data
(calendar entries, contacts, tasks, notes, and memos) between your BlackBerry smartphone and your Mac computer.
In order to synchronize with Microsoft® Entourage, Apple® Sync Services functionality must be turned on in the
Microsoft Entourage application. To accomplish this, complete the following steps:-
note:-Back up information and data before changing any settings on your Mac computer.
1) If the BlackBerry smartphone is connected to the Mac computer, use the Eject option to remove the BlackBerry
smartphone from the Mac computer.
2) Close the BlackBerry Desktop Manager.
3) Open Microsoft Entourage.
4) On the Microsoft Entourage menu bar, go to Entourage > Preferences.
5)Within General Preferences, click Sync Services.
To turn on contact list synchronization, select the Synchronize contacts with Address Book and MobileMe check box
To turn on calendar synchronization, select the Synchronize events and tasks with iCal and MobileMe check box
note:- When Sync Services has been enabled and the OK button is selected, a new dialog window appears with the following choices:
1)Replace Entourage items with Sync Services items.
2)Replace Sync Services items with Entourage items.
3)Merge Entourage items with Sync Services items.
For Additional Information:-
Before the BlackBerry smartphone data is synchronized with the Mac computer, verify that Sync Services is turned
on in the Mac OS X iSync application. This is done by completing the following steps:
1)Open Applications on the Mac computer and click iSync.
2)In the iSync menu, click Preferences.
3)If necessary, select the Enable syncing on this computer check box.
Oct 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
  1. In BlackBerry Desktop Manager on the computer, double-click the Back Up and Restore icon.
  2. In the Back Up and Restore window, click Advanced. The BlackBerry device database information will populate the right hand side of the window.
  3. Scroll down through the list and highlight Phone Call Logs, and select Clear. Note: If you are unable to clear Phone Call Logs, delete the Desktop [SYNC] service book on the BlackBerry device. This can be performed on the BlackBerry device by selecting Options >Advanced Options >Service Book and clicking Delete.
  4. Once the Phone Call Logs database has been cleared, disconnect the BlackBerry device from the computer, and then re-connect it to obtain a new Desktop[SYNC] service book.
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader in the BlackBerry Desktop Manager to erase all data and applications from the BlackBerry device. Refer to KB02318 for these steps. Once Application Loader has completed, perform a syncronization or advanced restore to restore the data to the BlackBerry device. To do this, double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
May 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
Backing up
How you restore your data depends on what mobile device you use. But your data is backup up every time you sync using Palm Desktop, Active Sync, Windows Mobile, etc. If you have a treo or similar device they'll even backup your data directly to Outlook.
There are also 3rd party SIM backup programs, these I don't prefer because you need the device to restore them and it complicates situations where say your Palm device crashes and you want to restore to a Windows device instead.
Aug 04, 2008 | RIM BlackBerry Pearl 8100
Hot sync
Try reseting the palm.
Jan 02, 2008 | Palm Treo 680 Smartphone
Computers & Internet Logo
230 people viewed this question
Alun Cox
David Payne
David Payne
