Question about Casio TC-930 900MHz Cordless Phone
Pick up rings
I have lost my manuel and can not figure out how to stop the machine from answering on the very first ring. I would like to set it for 6 rings. How do I do that?
  • 944 Answers
Here is the manual for the TC-919 which is very similar http://www.casio.com/support/manuals/telephones/tc919.pdf right in the top left of page 1 is a descrition of the ring select switch on the back of the base unit - this model can be changed only between 2 and 4 rings, but perhaps there is an option for 6 on your model The way to get a manual for your exact model if this one doesnt answer your questions is to call 609-395-0154 and request one. Hope this helps - please ask again if you have no success :)
Posted on Apr 12, 2007
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How do I get the answering machine to pick up on 4 rings?
Make sure you've got the machine set to answer calls, and set the number of rings to four. If you need a copy, you may download the manual here.
Apr 23, 2012 | Radio Shack (43-3829) Digital Answering...
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
Answering machine not picking up on 4th ring
Check to see if the battery needs to be changed. I did, and it worked for me.
Dec 16, 2009 | Radio Shack (43-3829) Digital Answering...
I need to set the rings
Rings to Answer:
THIS SETTING ALLOWS YOU TO SELECT THE NUMBER OF RINGS BEFORE THE UNIT ANSWERS A CALL.
1. The unit announces, "Rings to Answer (the current rings to answer setting). To set rings to answer press NEXT. Press SET to continue.
2. To chantge the rings to answer, press and relase the NEXt OR GREETING/PREVIOUS button and the unit announces a number, such as "2,3,4," or "2, toll saver, 5."
3. After choosing a number, press and release the STOP/SET button to store the rings to answer. The unit confirms the setting and enters Message Length menu.
Taken directly from the instruction booklet that came with my GE 29888GE1 instructions.
Hope it works for you ! jp
Mar 02, 2009 | GE 29888GE1 Digital Answering Machine
Can not set no of rings on old sprint answer machine SP818 please help
Ring Select and Toll Saver
Use Ring Select to choose how many times the line will ring before the
system answers a call. Set for 2, 4 or Toll Saver. When you set the
system for Toll Saver, it answers after four rings when you have no new
messages, and after two rings when you have new messages.
1. Press and hold [SET UP] for about two seconds. The system announces
the current ring selection.
2. Press and release [ANN/SKIP] or [MEMO/REPEAT] until the system
announces your ring selection.
3. Press and release [PLAY/STOP] to exit
-OR-
Press and release [SET UP] to change the Remote Access Code (follow
Steps 2-5 under "Remote Access Code").
Oct 01, 2008 | Lands Phones
I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Aug 28, 2008 | Office Equipment & Supplies
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Casio TC-930 900MHz Cordless Phone Logo
200 people viewed this question
Top Casio Lands Phones Experts
ka4iup
ka4iup
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Casio Lands Phone Expert? Answer questions, earn points and help others
