Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD player does not work
I have the DVD player hooked up to the Sony Bravia KDL-40S2000 via the Panasonic VCR. It worked fine till someone changed the settings on the remote. Now I can't get the DVD player to work. Any ideas?
    Genius:
  • 1,011 Answers
Sir,
Check all the settings thr. remote.
You can substitute the HDMI cable for composite from the cable box to the TV. Use the other for the DVD to TV (without the sound red and white).
Cable to VCR: in on the VCR, out on the cable box/
VCR to TV: out on the VCR, in on the TV.
Don't use the DVI/HDMI cable.
Speaker wires go to the DVD player. Nowhere else.
Posted on Dec 24, 2008
  • Sony Master
  • 13,433 Answers
Try unpluging the dvd player for 10 minutes and try again, try restoreing the player to default settings.
My new tv suddenly clicks off and goes totally green.this is new sony lcd and other lcd did this also so must be my sat equipment, yes
Please hook DVD player with TV and check TV still gives same green screen problem with dvd playback?
If TV works fine then satellite box sounds bad and need to be confirmed by hooking it with another TV.
Dec 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 40S2000 when switching to HD video goes black
Contact Sony. There is a software update for this. Go to www.Sony.com for contact information.
Nov 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40S2000 "Bad LCD"
THERE ARE NO COMPONENTS TO BE REPLACED ON THE PANEL. THE PANEL MUST BE REPLACED.
Mar 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Recording
I think it should be possible. As long as you don't exceed the resolution of the DVD player. It should work fine. Just keep DVD player in Rec / Pause mode then hit Rec button when you want to record a clip, then pause it again. That should work fine. Have a good night. Jay
Jan 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
