Reset code 2205 of oce 7051
Excuse culde u help me the steps to reset tihs code plz??
i need to ur help urgent
thx
  • jpd8 May 11, 2010
    We need to know the make and model, PLS.
  • Office Equip... Expert
  • 211 Answers
For what model do you speak me and no body else can't help you if you do not name the machine brand and model
Posted on Jul 15, 2009
I have an Oce 7051 printer which I have had from new but which has not been used for about 5 or 6 years. When I tried to use it there are no lines at all on the copy sheet. I put a new genuine toner
If you have left the ink cartridges in the printer unused for 6 years then the ink has dried in the printer heads and these need to be cleaned or replaced,
Aug 29, 2014 | Office Equipment & Supplies
Prints are coming out ''dirty''.Oce 7051
when printing a file, in most cases it's the photoconductor unit (also called 'drum') that needs to be replaced. if this did not help, it may also be the fusing unit.
when making copies, it may very well be smudges on the scanner glass.
Apr 22, 2010 | Office Equipment & Supplies
Nokia 2626
i forget my code plz help
Jun 27, 2009 | Nokia 2626 Mobile Phone
Change language
how i culd change my languge from german to english, could u give assistme to do that ? thx for ur help
May 27, 2009 | O2 Xda Atom
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
Nokia E90 forgotten lock code
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
Dec 15, 2008 | Nokia N70 Cellular Phone
Were is the drum cartiage located in the m128, says its not inserted right
You have to open the front cover and the left side door to access, it is located inside the front cover on the right sife of the machine.
You have to unlatch it and re insert it .
Dec 11, 2008 | Xerox WorkCentre M128 Copier
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
155 people viewed this question
k24674
Marvin
Marvin
