Question about Sharp AL 1631 Copier
Green blinking light CH
I recently changed the toner in my sharp al 1631 copier. I keep getting a green blinking light 'CH' what does this mean?
  • wyandotte68 Dec 25, 2008
    You have to make sure the side door and front door are close.
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Posted on Dec 31, 2008
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I am getting a ch message on my sharp al-1631 copier and can not find the manual. Do you know what this means?
CH stands for close hatch check that the front and side doors are closed. (open both then close again)
Jun 21, 2011 | Sharp AL 1631 Copier
If the "CH" blinking check and reinstall the toner cartridge properly , if not that mean you the one of the copier door is open.
Jan 05, 2011 | Sharp AL 1631 Copier
We have a Sharp Model AL-1631 unit that keeps running but doesn?t make copies. Any idea what is wrong and how to fix it? Thanks.
When these Sharp AL series machine just run and run it means they are low or out of toner. This is especially true if you are hearing a light thump thump noise while it is running. Just let it run and after 5 minutes or so it should shut down and then replace toner light should come on. This is the small red light that looks like a stack of 6 dots.
Either replace the toner or have your existing toner refilled.
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL 1631 Copier
What does message ch mean?
If your copier front or right cove is not attached properly then CH on standby, or CH is blinking/flashing may be your copier TD unite is not adjust or close.
Dec 28, 2009 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
The CH keeps blinking on my canon AL 1631
These units are notorious for having slightly ajar front doors. Check to make sure it's sealing up properly to the door locking catch, else the door sensor may be showing you the 'CH' indication.
Aug 31, 2009 | Sharp AL 1631 Copier
What does "CH" mean?
On the Sharp copiers when the "ch" is blinking means that the toner cartridge is not in or it may be the wrong cartridge. Some sharp cartridges look alike and will fit into the machine but are the wrong one.
Hope that helps...
Feb 18, 2009 | Sharp AL-1642CS Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
258 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
