Question about Dell Dimension E310 PC Desktop
Dell e310 message "no dialtone" for dialup but ph co says line ok
If i need a new modem suggest an external modem with ubs connection cannot disconnect computer from gate operator
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    I am sure you have tried this, but I have to ask...
    Are you sure the phone line to your comptuer is live, many times it gets loose or does not connect properly. The best way to tell is to attach a phone to that line (not outlet) and make sure you hear a dial tone.
  • Dell Master
  • 998 Answers
Here's a link to several models; Robotics has a reputation of being the one of the first and most dependable models.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Dec 25, 2008
Hyperterminal dialup connection using MagicJack connects to other modem but cant type any text
Magicjack is designed as a Voice over internet protocol (VOIP) device, not used for modem calls.
The devices will not synch.
Jul 19, 2012 | Computers & Internet
I have s dell studio 15 laptop. i got a dell conexant rd02-d400 modem so i could use dial up with it. now i get errors that say it can't connect, but that everything os ok.. error 692 and 618 (i think)...
Connect your modem to the phone line and test the modem.
Control Panel-->>Phones and Modems. Click icon. Tab Modem. Highlight your modem, and Click Properties--->>Diagnostics. Verify that everything is OK.
Then Start --->>All Programs -->>Accessories-->> Comunications ---Hyperterminal.
Enter a name for a bogus connection, Click OK
Enter your phone number and dial it. If Phone/Modem connection is OK, you shoul hear the busy signal.
Alternative:Run the Dell diagnostics.
If Modem connection is correct you must then create a dialup connection.
Hope it helps.
Sep 12, 2009 | Dell Computers & Internet
Laptop Vista dialup modem - Access Limited Connectivity
  • Window update running will definitely affect your dial-up connection, but you should be able to connect faster...
  • See this article
  • Go to start>control panel>classic view>double click Network and Internet connections>click network connections>right click your connection>select properties>under General tab make sure that the device listed is your correct modem-click configure-make sure the Enable modem compression box is "unchecked"-click ok to save changes-click ok to exit.
  • Make sure you have the latest drivers available for your network adapter, consult the MS Vista Network troubleshooter available here
  • You may wish to use your Device Manager to review your hardware and address any problems that appear there.
  • Monitor processes use using task manager or process explorer to see if your ram is being taxed unduly by the running processes. (I mention this because Norton is known to be a bit heavy handed in its use of system memory, you could try an alternative AV like Avira, Kaspersky, Eset NOD32 and see how it affects connections).
  • Vista Networking
  • You might want to read through some of the posts in this forum, and see if there are any posts that answer your issue.
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 23, 2009 | Toshiba Satellite X205-SLI1 Notebook
The modem is extremely slow-most downloads are far too slow
Dialup phone lines usually only transmit a minimum of 8 Baud. NetZero's high speed (5X) faster is done by caching pages you have already visited, not actially running internet but loading pages faster on your computer. Check your modem setting, 56k, 112K are normal speed setting to connect. Check your actual connection speed, 28.8 is probably all that you are getting on dialup.
Feb 01, 2009 | Hiro (H50113) Analog Modem
Modem dialtone problems
Is the phone line going to the modem live?
Jun 25, 2008 | Intel Motherboard
No modem
put your modem in another pci slot and try again.
Dec 08, 2007 | Acer Aspire™ T180 PC Desktop
How to install a modem in gx150
I really wouldn't bother with dialup anymore, you can get a broadband package for the same money.
if you must use dial up, to install a modem,   you can use an external modem which means you don't have to open your pc(invalidating any warranty).
if you really want an internal Modem you can get a PCI modem which can be easily be installed into a free PCI slot,
If your board has an AMR/CNR slot (a small slot specifically designed for modems/network cards) you can buy a modem for that slot (which does not use one of your PCI slots)
Oct 30, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension E310 PC Desktop Logo
Alun Cox
