Question about Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black
Only 3 speakers work!
I docked my IPOD and only 1 front and 1 rear speaker worked. I reseated the IPOD and both front speakers and 1 rewar speaker work. No matter what I do, I can not seam to get the 4th speaker to work. Any suggestions before I return it and buy a Bose?
Thanks for the help.
FF
  • saskwatched Dec 28, 2008
    Hi Fficarra. Yes, we've had a similar experience with the rear "speakers" on my wife's go + play. However, I'm not sure it's a problem. From what I can tell by looking through them under a bright light, & from reading a bit about H/K's "Slipstream port" technology, the matching speaker grills on the back of the unit  do not house separate speakers. That is, the unit's 2 woofers & 2 tweeters are under the grills on the front of the system (you can plainly see this by looking under those grills), & the grills on the back merely port some of the sound from the back of the speakers to the exterior. I think the left rear port (to the right channel/speaker) throws more sound than the right rear port (for the left channel) b/c there's some kind of dampening device (a plastic insert with slits cut in a diamond pattern) over the right rear port just under the grill. The port under the left rear grill is wide open, which allows for most of the bass coming off the back of the right channel's woofer to escape. Because the cones can travel as much as an inch back, the bass flying out of the right channel's front & rear grills actually creates a wind. If you listen closely, you'll hear that some sound does come out the other rear port but it's more muted. I'm calling Harman/Kardon's support line on Monday just to be sure. I'll post whatever I find out. In the meantime, hold back on your plan to return this for a Bose. I've compared Bose & H/K side by side & the H/K delivers a fuller range of the sound & clear, undistorted music at much higher volumes than the Bose is capable of reaching.
  • hopeful09 Jan 12, 2009
    Any news saskwatched ?
    I have the same problem. With mine, only the 2 front speakers work... :-(
I took the bottom off my go play to have a look inside, the internal port is connected to one rear speaker grill and the other is blanked off, so no sound will come out of that one.
Posted on Apr 11, 2009
    New Friend:
One of the rear bass ports on the go+play is a passive speaker. It does not give out any sound and this is why you dont hear any. It simply helps to boost the bass, similar to what you see on subwoofers with holes on the side.
Posted on Dec 31, 2012
    New Friend:
Guys, I experienced the same. The front speakers worked and rear not. BUT please remember, that this was on batteries. As soon as I plugged in the normal electricity (adapter), all speakers, rear and front, worked like a charm.
Posted on Feb 23, 2013
  • 1 more comment
  • Stary kocur Feb 23, 2013
    So it is not a bug, it is a feature
  • Andrey Adzhiev
    Andrey Adzhiev Apr 13, 2014
    It's impossible. All you have on rear side is phase inverter and plastic cover behind aluminium grill. Check this:http://i-lak.ru/image/data/akustika/gopl...
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
Does this work with the ipod touch 4th gen
Here are it's features
Product Features
  • Portable speaker/display system designed for all "dockable" iPods**
  • Crystal-clear, 7-inch widescreen LCD display with 480 x 234 resolution
  • Pair of aluminum cone neodymium drivers and Class D digital amp
  • Built-in iPod docking station; 3.5 mm auxiliary input for other devices
  • Measures 8.7 x 1.7 x 6.5 inches (W x H x D); 1-year warranty
Notice
Notice it say ALL iPods, as long as its not the 5th gen ipod with the new dock connector it should work fine.
Oct 14, 2012 | Sonic Impact 5090 Video-55 LCD Video and...
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Sep 18, 2012 | LG 5.1ch 1100w bluray hts 5 speakrperp...
Hi. I just bought a new JBL On stage micro III. The problem is that when I put my Ipod on the dock the sound only comes from the iPod and the speaker doesn't produce any sound at all but when I push...
Have you made sure the dock is compatible with the iPod version you have? If you are having to move the iPod around, this may be because the dock isn't built for the iPod you own.
It could also be a technical fault that the dock is loose. Take it/send it back to the shop and explain your problem.
May 06, 2011 | JBL 6-1/2\ Round Coaxial Speaker By...
IPod Touch 4th Gen will dock. Will Charge. Can use remote control to play, and shuffle songs from iPod, but sounds will not come through speakers on Philips SBD8100 Speaker Dock for iPod and iPhone
Hi Sniper326,
try cleaning the input socket of the Philips Speakers with a cotton bud, try cleaning the socket of the Ipod touch cable as well.
Have you tried using the IPod touch with different speakers? and does it work? if so the problem lies with your Philips speakers.
I hope this helps, good luck!
Mar 15, 2011 | Audio Players & Recorders
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Dec 20, 2009 | Audio Players & Recorders
Wont play out of docking speakers
Hi
My iPod does the same it does not play out certain speakers.
Take back the speakers.
Take back the ipod.
Go to:http://www.apple.com/support/
Tom
Jul 05, 2009 | Apple iPod touch
I cant get my ipod nano 2g`s speakers to work when docked?
i tried it again and it didnt work so i went back to argos and got another one and it worked then it was my 1st ipod it was faulty lol
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black Logo
1,019 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
