Question about Intel SuperMicro SUPER Motherboard - 810 (370SEAO)
Motherboard BIOS I've tried to clear the cmos, but i don't know for how long, guess i'm a rela dummie in this. My motherboard still doesn't beep when i plug it and from what happened when the power supply shorted, it didn't affect the motherboard or so it seems. Does anyone have any solution for this?
Have you tried removing the bio battery to reset the bio it might work
Posted on Aug 20, 2007
    President:
  • 2,961 Answers
Unfortunately if you can't get in the bios, no beeps and assuming the memory is compatable with the motherboard, then the bios chip is damaged and there is no way forward apart from another board.
Posted on Apr 12, 2007
Gigabyte bios rom error beep code
http://www.gigabyte.com/products/product-page.aspx?pid=3013#dl new bio here
Dec 03, 2013 | Gigabyte GA-EP45-UD3R Motherboard
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
I have bought the used hp sp323071-001 ,I want to boot by DVD-rom but it doesn't boot and the bios has got a password which I don't know what it is , I tried to reset the password by removing the...
you could try Compaq as the bios password some manufacturers place this password on there computers for maintanance reasons
or you might
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard. If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (integrated circuit) on your motherboard. Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. RTC's which require external batteries hope this helps
May 29, 2011 | HP Compaq Motherboard
I am using via cn896 motherboard and i have set bios password, right now i forgot that what password i have given, than i try to clear the password doing remove the cmos battery but still password is not...
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don
Mar 25, 2011 | Biostar Viotech 3100+ VIA CN896 mATX...
Problem with the Intel Desktop Board DG41BI\r\n I
setting the memory is pointless as the system will automatically find the best speed for it if its set to auto. As for the 3 beeps that is generally vga, but could be different on this motherboard , when you clear the bios do you move or short a jumper
Mar 11, 2011 | Intel Motherboard
VGC-RB42G flashig power light and won't power
I have had this problem if power is removed by disconnecting the power cord (in cases where nothing else works). To fix the problem:
1) remove the power cord from the back of the unit
2) disconnect the large power connector from the power supply to the motherboard
3) apply power to the power supply
4) reconnect the motherboard power connector
5) turn the unit on
- dedndave
Apr 13, 2010 | Sony VAIO VGC-RB42G PC Desktop
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
Clear bios settings on m963gv motherboard
You have to shut off the power and then move the clear CMOS jumper on the motherboard to the clear position for just a few seconds. Apparently the manual that shipped with m963gv may not have the right information as to the location of the CMOS driver. Try going to PCCHIPS's website and download their manual in PDF form:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=354&DetailName=Manual&MenuID=7&LanID=2
You'll find the CMOS jumper location on page 11 of the PDF file (or page 6 on the printed format). On Page 15 is the instruction on where to place the jumper (again, when it's printed, it's labeled page 10).
Nov 04, 2008 | PC Chips M963GV (V3.3A) Motherboard
Beeping
a constant beep ?
did you plug in the memory modules. check that they are seated properly.
make and model of computer would get you a more definate answer.
Sep 01, 2008 | Biostar P4M800-M7A Motherboard
Computers & Internet Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
