Panasonic AG-DS850 - SMD cap failures
Hi - would you happen to know or have a list of the capacitorslocationsthat commonly fail causing poor video? There is a ton of capson thevideo and Y/C boards.
Thanks in advance for any help you can provide.
Ken
    Champion:
  • 221 Answers
Best approach is to replace them ALL. what hasn't failed yet will do so in the future and come back to bite you. you can change out all the caps in an afternoon if you don't get interrupted.
Posted on Jan 21, 2009
I need the user manual for panasonic ag-ds555
I can't find one online either but the AG-DS850 manual should be extremely close if not the same (I can't see any differences in the front/rear controls except the model#): You can download the 850 manual here: ftp://ftp.panasonic.com/provideo/om/agds850_en_om.pdf
Oct 29, 2011 | Panasonic AG-DS555 S-VHS VCR
Defective monitor samsung 740n no display how to fix it?
Common failures are due to bad DC filter caps, look for caps with domed tops first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Hi there,pleace i need help.i have a panasonic dvc20,and during recording the message always appears : press the reset button.when i rest the camera,after some seconds of recording the same message appears...
the dvc20 performs a self-test routine which includes testing the operation of the mechanical deck. if one or more tests fail, the "press reset" comes up. most common problem is a poor connection to one or more motors in the deck; oxidation or dirty connectors causes this.
Dec 13, 2009 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Panasonic AG-DS550 VCR shuts itself down about 2 seconds after switched on. No error code appears in that brief interval. Toggling the power switch immediately is ineffective, but after waiting a while,...
This is a typical symptom of a power supply failure. There are some self-checks performed at power-up that are not completing correctly. Were there any symptoms before the complete failure? Often, the units start to behave strangely before complete shutdown. The power supply failure is tied to defective capacitors in most cases. These supplies are what are called "switch-mode" supplies and must oscillate to work. Defective caps will either not provide the kikcker to start the oscillation or prevent the oscillation completely. While there are other causes, this is the most common. AG units are professional decks and should be serviced by authorized service centers.
Hope this helps,
Dan
Dec 07, 2009 | Panasonic Televison & Video
The AG-188 video camera doesn't always record the sound or it get parts of the sound
Hello That is true when you ues this camera blow 32 Degrese I don'tt Know what else would cause it Justb the Cold thanks
Dec 04, 2009 | Panasonic AG-188 Camcorder
My panasonic AG DV2500 mini dv VCR hates loading and ejecting.
this loading problem in the AG-DV2500 is caused by a defective cassette housing. list price from Panasonic is about $375.00.
Oct 15, 2009 | Panasonic AG-DV2500 DV/Mini DV VCR
Part number(s) for the recording head(s) for the panasonic ADDV-7
Panasonic lists video heads for the AG-DVC7 at about $250.00. p/n VEG1576.
Apr 02, 2009 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Seems like TBC won't lock, blue cast, picture unstable, weird colors, no contrast
change in stability after warm-up is a sign of defective capacitors. the DS550 and DS850 both are notorious for capacitor failures. don't touch the trim pots unless you have a service manual and a wfm/vectorscope.
Nov 07, 2008 | Panasonic AG-DS555 S-VHS VCR
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
