Stereo Sap comes up - no volume - increasing channels unable to a
Stereo Sap keeps coming up on our screen - no volume - we had 2 channels in the beginning that stated that and now we have more and more channels with "Stereo Sap" what does that mean? what can I do to get those channels back?
  • Lisam_hgp Apr 02, 2009
    Stereo SAP comes up - no volume - increasing channels unable to hear now.....we have lost the original remote how do we fix this?
  • 520 Answers
SAP stands for secondary audio program. It can be used to broadcast another audio soundtrack, like spanish etc. Look on the remote for an audio button and try that. You can look in the menu if that doesn't work. If you find it, make sure it is off. If you can't find it post this problem again with the brand name and model number of your tv. I will try to find the solution.
Posted on Dec 24, 2008
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Stereo SAP will not come off a few channels , no sound on these channels
Do a factory reset to this set. The Secondary Audio Program [SAP] to all channels will be cleared. Refer its user manual for details.
Mar 25, 2013 | Televison & Video
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
Lost volume on some channels
enter in menu, in audio side put in stereo, no in sap.
Apr 02, 2010 | iLO IWT3206 TV
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
Spectroniq PLTV-20NW32 volume only works on some channels
Hi lisadean767,
It is possible that without realizing, your TV is programmed to receive SAP or Second Audio Program audio. When this happens, your TV responds like this: when SAP is not being broadcast, you'll receive regular program audio. However, when the SAP audio is sent along with the regular, (English) program audio, your TV will automatically switch to the SAP channel. You'll know your TV is programmed to receive SAP because you'll hear the commercials in English and any other program in English if the SAP is not being sent.
Check and see if your tv is setup for SAP. Let me know if this helps and if I can be of further assistance, Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 22, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
Nov 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
CT-36D12
Instead of explaining the SAP/Stereo function to you, the easiest way to get the TV back to normal is while the set is on press the ACTION and POWER buttons at the same time and hold them until the CHK screen appears. Once that does release the buttons and then press the action button again to exit the CHK screen. Your TV is now back to the factory settings and will need to have the channels programmed again. By the way the SAP/STEREO button on the remote should be near the upper left hand corner of the remote itself.
Mar 25, 2007 | Panasonic CT-36D32 36" TV
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
