Question about GE Nautilus 24" Built-in Dishwasher
Ge nautilus/dw genautilus dw has elec/filled with water and will not advance and finish cyles....won't wash
  • 71 Answers
It sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Posted on Dec 24, 2008
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a GE Nautilus dishwasher GSD2230F01WW is it hooked into the hot water under the sink or the cold ?
It should definitely be hooked into the hot water...and the temp of the hot water should be around 120degrees and not to exceed 150 degrees as dish damage can occur. There is a heat assist in the DW that helps to heat the water temp also.
I hope this helps....good luck and good day...thank you for rating my effort....The Fang.
Mar 02, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
181 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
