Question about Olympus FE-130 Digital Camera
Olympus FE-130 Hi all I keep getting a message saying that the battery/memory card cover is open even though it is securely closed. Any ideas? Thanks. Elemc
On the above image you can see how I solved this problem. I used the way discribed in solution #2. I first broke off the little box and then added the little copper wire contacting the piece of iron at its left. Now my camera works again.
Posted on Mar 04, 2009
  • Aebele Mar 04, 2009
    I used the solution of Guest, not #2 posted on nov the third, not the other one that I named under my photo.
  • Domagoj Bozic Nov 15, 2010
    Basicaly, only two wires need to be shortcuted (connected with wire) and it will solve the problem.
    After I lost this white stich (which caused all our troubles), unscrewed (only) 6 screws, opened camera, removed white plastic box which is placed at position this picture shows. After that two metal pins (only one is shown in the picture, which were surrounded by already removed white plastic box) have to be shortcutted.
    Anyway, thank for very good picture.
I had the same problem with mine for a while. Just jiggle the memory card around a bit with your finger, and close the cover again. It should then work. It's a tempramental thing though. Just keep fiddling with the memory card until it works.
Posted on Apr 14, 2007
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Posted on Nov 03, 2007
Send it back to the manufacturer. Hope it's under warranty or you can get your retailer to back you. This is a design flaw. There is a tiny plastic spear and spring that can break off in a breeze and you won't even know you did it while replacing a battery or adding a memory card. I've seen dozens of troubleshooting queries on the web just like this and I've had to send the camera back to Olympus to be fixed.
Posted on Sep 05, 2007
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
When I turn my camera on, it says 'Battery Cover Open' even though the cover is securely closed and the battery is fully charged. Any suggestions?
Hi!
The switch that detects if battery cover is closed is broken. You can open the battery cover and look under it, you should see a small hole with a small black switch in it. If you have experience in repairs and / or soldering, you can fix it yourself - just shorten the switch. If you can't do it yourself, just give it to any local camera or mobile phone repair shop, they should be able to do it without problems.
Hope this helps!
Tom
Jul 31, 2009 | Olympus FE-230 Digital Camera
Olympus FE-5010 Card cover open error. Card cover is closed. Tried a new battery and new card. It didn't help.
i hv olympus fe 5010 nd problem is "write protect" error sawing .....so how i cn solve it
Jun 27, 2009 | Olympus FE-190 Digital Camera
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 11, 2009 | Olympus FE-190 Digital Camera
Card Cover Open
The problem you are describing is a problem with the sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Mar 28, 2009 | Olympus FE-130 Digital Camera
Every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Jan 20, 2009 | Olympus FE-310 Digital Camera
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
Hi X,
There's a little piece of plastic on the battery cover, that presses a switch when you slide the cover closed. Check that manually with a tooth pick and the the battery in place. Don't smash it. I have a Olympus FE -280 and it only happens when I put the cheap Chinese battery in.
If you are in the least uncertain, call Customer Service.
Best regards, Paul
Jun 12, 2008 | Cameras
My screen keep showing the Card Cover Open Error even though the cover is closed. What can i do It says "Card Over Open" when it is closed
The card door sensor is either damaged, failing or gone completely. You can take camera apart, (7 screws I think) take the back off. Sensor is at the back of camera near the battery door. If sensor is missing, you will see 2 spots on the electronics board where it was connected. Carefully melt solder so that those two points are connected. If sensor is still in place it's probably damaged. Carefully remove sensor using small snips or something like that, with out damaging anything around sensor. Then solder 2 points together. Good Luck
Apr 09, 2008 | Olympus FE-190 Digital Camera
Error message: card cover open..yeah right
Hmmm, I'm thinkin' if there's no memory card in camera, there are NO memories, aka formerly known as photos. Unless there is some sort of an internal memory, but me thinks not. As for error message, might be because....card fell out while an image was being captured.
Apr 28, 2007 | Olympus FE-130 Digital Camera
Card cover open message
it´s pretty normal to hapen on that camera, the swith breaks a lot, u will need to send it to the service centre to get replaced that swith.
Jan 12, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 Digital Camera Logo
1,014 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
