Question about Brother MFC 7420 All-In-One Laser Printer
My pc brother mfc7420 copy but keep printing blank paper
  • wtart May 11, 2010
    Does this happen only when you are copying or does happen in all modes printing, fax printing, printing from computer, as well as copy printing
    Champion:
  • 320 Answers
Shut the machine down, remove the ac plug from the machine and take the printer cables out of the cpu. now waite 20 min and reinstall everything, this is a starting point. let me know and  i wll get back to u we are a brother service center
Posted on Jan 13, 2009
WHY DOES THE MESSAGE MANUAL FEED INSERT PAPER KEEP COMING UP ON MY MFC7420
if you are trying to print something from your PC and machine has NO paper in tray she will ask you for manual feed. Look in your printer driver properties to see what PAPER SOURCE is chosen.
pifonski
Feb 20, 2011 | Brother MFC 7420 All-In-One Laser Printer
Faxs received are blank. Copies are printing
Can't happen. Someone is faxing papers upside down to you.
Copying and receiving faxes uses the same exact printing process.
Oct 26, 2009 | Brother FAX-8360P Plain Paper Laser
Receving large unwanted faxes
Please rate my solution. Hope this resolves the problem.
According to the manual one of the things that can cause this is if the data cable (USB) was disconnected from the printer while the job is printing. Press the Cancel button on the printer, that should clear the memory. Also make sure you don't have print jobs in the queue if the printer is connected to a pc.
Manual can be downloaded at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Aug 28, 2009 | Brother IntelliFax-2820 Laser Fax
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Prints on copier not from pc
Try updating the driver, it should be available from Brother's website.
Sep 20, 2008 | Brother DCP-330C All-In-One InkJet Printer
Blank paper syndrom
Can you do a simple color or b/w copy job? If yes, the ph is OK and you might have to reinstall the drivers (delete before that the old ones).
If you cant see any copy job (blank paper) you should change to original carts and run the manual cleaning procedure twice. Wait a few hours an try to do the printing again. You might have to run the cleaning procedure twice again!
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
Brother MFC 7420 All-In-One Laser Printer Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
