Question about Onkyo HT-S790 System
Power cord cut can it be fixed
My power cord to my onkyo HT-S790 on the av receiver was cut can it be fixed
  • Official Brand Answer
  • 333 Answers
Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at parts@us.onkyo.com. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding Onkyo Parts and Accessories. Please note: some parts are not available to be sold to the public and are only available to be sold to authorized Onkyo service facilities. You will need to speak with the Parts & Services department for any parts ordering/ shipping status, and availability or specifications for Onkyo parts and accessories.
Posted on Apr 05, 2015
    Genius:
  • 1,175 Answers
HI...
Is the power cord the type you can unplug from the unit?
If so, go to radio shack and get a new one.
If not , do something like KNtech said but if you cant solder , you can use 2 wire twist caps that connect wires together.
Go to a hardware store and show them what needs to happen and they can help.
Posted on Feb 08, 2009
  • 34 Answers
Yes, strip the wire from both cut ends. then find the same color wire, and solder them back together. then isolate them from eachother and your good to go.
Posted on Dec 24, 2008
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
My onkyo ht-r590 goes on then shuts off right away.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Oct 01, 2014 | Onkyo HT-R590 7.1-Channel 3-D Ready Home...
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
Hookup diagram
easy.connect the dvd trough optical cable to the amplifier home theatre for surround sound and the video where it says DVD input and the sony cassete deck where it says cd in A/V the red cable wwhite and yellow,
Jan 20, 2010 | Onkyo HT-S790 System
Comcast remote/Onkyo AV Receiver
I have this exact same problem. Anyone know how to fix this?
Dec 22, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Onkyo HT- S790 installation manual
You can find manuals for Onkyo products here http://www.onkyousa.com/download/own_manuals.cfm
Jul 22, 2007 | Onkyo HT-S790 Home Theater System System
CORRECT SETUP CODE FOR RECEIVER
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
Onkyo HT-S790 System Logo
701 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
