Question about Maytag MGR5880BDS Gas Kitchen Range
Oven will not bake, but broil works
When I turn on my Maytag MGR 5880 BDS using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Thank you
  • 71 Answers
The bake ignitor is most likley bad
Posted on Dec 24, 2008
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Hi. I have a Maytag CWE4200ACB wall mount oven that seems to have a circuit board/timer problem. When the oven is turned on and temp set you can hear (at the control panel) one click and the "on"...
Hi.
The clicking noise comes from the control board relays. The board has three relays. One for for bake. One for broil. One for light/fan auxiliary functions.
Try switching on only bake or broil. If one of the two elements (either bake or broil) gets hot, then the problem is either element or timer board. Make sure that the element has continuity at the Ohm meter.
If both bake and broil do not work test first the oven temperature sensor located inside the oven cavity. Make sure that impedance of the sensor at room is about 1.1KOhms . If sensor is open or shorted, replace the sensor. If sensor reading is OK test wiring and elements for continuity and eventually replace the control board if the rest is OK. Even if door switch should not affect regular programs, check the door switch reading impedance or jumping it.To test wiring test continuity of red and black lines. Check black line between power cord and relay board. Test with particular attention the oven temperature sensor, that is a common cause for your symptoms. Here the part:Long Oven Sensor Kit
Here a wiring diagram for your oven.
Here all parts and diagrams.
Regards.
Ginko.
Nov 15, 2011 | Kitchen Ranges
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My sister has a Maytag Advanced cooking system - MGR 5880 BDS - they used the self clean last night and now today the door will not come unlocked and a error F9 is showing on the display. How can they fix...
The F9 code indicates that you have a problem with the door lock circuit in this type of range. It is possible that you have a wiring failure in the door lock circuit. I recommend that you unplug the range and check the wiring connections on the door lock switches. I provided a wiring diagram in the image below. If you find no wiring problems, then you could normally try to fix this problem by replacing the door lock assembly.
Mar 20, 2011 | Maytag Kitchen Ranges
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Maytag MGR5880BDS Gas Kitchen Range Logo
683 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
