Question about Epson Stylus C86 InkJet Printer
Epson C84 - no power
Turned on my Epson C84 - nothing happened. Machine remained dead. Checked wall outlet and power lead on another appliance - both o.k. What's gone wrong?
  • Epson Master
  • 691 Answers
Most likely cause is the power supply has let go. It could be a fuse inside the power supply. You would need a servie manual to get you in to the machine to check if a fuse is present on the PSU. Try either of the following: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com (Join his list to see all the files available) Either of these should help you get a manual
Posted on Apr 12, 2007
All of a sudden the microwave will not coming on at all no clock no nothing, it completely lost power. I've tried a different outlet and it has no power. Did it blow up?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 07, 2011 | Tappan Microwave Ovens
I have power to the unit, I checked the fuse - OK - nothing working on unit
Hope this helps.
Mar 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
I was warming a cup of coffee in a ceramic cup. The microwave ran for 2 sec. and then totally shut off. nothing works. we checked the outlet, the circuit breaker and everything has power to it
Hope this helps.
Feb 02, 2011 | LG Microwave Ovens
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
Quit working totally. Checked outlet and have power. Is there a fuse in the oven itself? Reset Switch?
Hope this helps.
Jan 07, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
My microwave made a funny noice a couple of nights ago, but continued to work fine after that but now it's completely dead. Checked the breaker and it's fine. Any ideas?
YOUR SAFETY IS PARRAMOUNT!
Hope this helps.
Jan 05, 2011 | GE JE1640 Microwave Oven
Wheelwriter 6 Typewriter won't come on.
When the switch is turned on, the machine sholuld cycle all the motors and home the carrier to the left margin position and one of the linespace lights whould be on. If the machine does not cycle at all:
  • Make certain that there is power to the outlet (try a known working appliance or light into that outlet)
  • Ched that the line cord is securely plugged into the wall outlet
  • Check that the line cord is securely pluggted intor the back of the typewrtier (you can wiggle it while the power switch is on and see if the machine reacts)
  • Flip the switch on and off several times, including a flicking motion
Nov 09, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Dead Epson C84
The power supply inside your printer has failed. Unfortunately the C84 model does not feature a replaceable power supply. Sorry, but when a C84 power supply fails, you have little choice except to extract the ink cartridges and throw out the printer. You asked if this problem could have been caused by switching power at a point other than the switch on the printer. The answer is, "No." It's okay to power-cycle a printer this way. However, if your nickname of "portugal" truly indicates that you actually reside in Portugal, I would consider getting a "line conditioner", which would protect your printer (and your other computer equipment as well) from unfriendly spikes or dropouts in electricity. By the way, in the U.S. the phone number for Epson printer support is (562) 276-7525.
Mar 30, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
