New thermostat. new potentiometer. vacuum operated valve in heater line works. blend actuator only works when opened and jumped to the motor inside, but not when plugged to the harness. al fuses are good. bad board in the actuator? what else can it be ?
SOURCE: Temperature of A/C or Heater will not change to
Since all mechanical parts are in working order then the problem is in the logic part - the blend doors don't move because they aren't commanded to do that. The only thing that would do that is the failure of the climate control module - you will have to replace it.
SOURCE: 2003 grand marquis blend door not working does not seem to have power to motor
control head is probly bad
turns out the actuator motor was good but th pc board was bad.
