Question about Pentax MZ-50 35mm SLR Camera
Pentax MZ 50 film winding problem
When the camera on/off switch is turned either on OR off, or when the batteries "chamber cover" is closed (with the on/off switch in either position), the film will advance one frame per action. The same will occur when the shutter release is half pressed, or when the Select Switch is moved either right or left, or when the Exposure Compensation button is pressed. The advance is reflected in the LCD panel indicating number of frames used and the motor can be heard. also the auto focus is heard. With the camera is turned off, none of the above occurs. When the film has been advanced to 24 frames, the film counter flashes 24 with the camera turned on OR off and will not advance past 24. At 24, the film will not rewind automatically. Opening the camera comfirms that the film has been winding on. On closing the camera the film counter flashes E with camera turned on or off. Using the mid roll rewind button will rewind the film and the flashing E will stop only after the rewound film has been removed. Re-inserting the rewound film will result in the flashing E appearing. The camera is loaded with a 24 frame film. The Mode dial is selected to PICT. The Mode Drive Switch is selected to single frame. Selectin AF or MF mode makes no difference. New batteries have been fitted and there is no battery low indication in the LCD panel. The batteries are fitted correctly. Owners maual offers no solution. Because of the above problem, the mid roll rewind button was used successfully and the film developed OK. Over to you
  • picturemagic May 11, 2010
    Are you saying that the camera is actually taking pictures at these times? i.e. when you had the film processed, did you have pictures, even though the camera may not have been pointing at your intended subject.
  • 4 Answers
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Posted on Mar 26, 2010
Wont turn on
I assumed that you loaded a fresh battery set and with correct polarity ,otherwise it does give such signal.
If you have the user manual,please check the other alternatives on trouble shooting section.
If you do not have a user manual you can visit the site below where instruction manual copies for Pentax,
www.pentax-manuals.com
It's not an official site, but the manuals for downloading are better quality copies and in color
where possible: and they have the MZ30 too.
Regards
Mar 16, 2010 | Pentax MZ-30 Film Camera
Camera shoots all the film then rewinds.
Repair would be at least $139 from Blue Moon Camera. I would buy another MZ-50 (ZX-50 is the same) off eBay or you could buy a ZX-30 from Blue Moon Camera for $75 with 1 year warranty. They are professional.
http://www.bluemooncamera.com/services.php
Jan 10, 2010 | Pentax MZ-50 35mm SLR Camera
Camera makes noises direct after inserting new
I'd be worried if it didn't. It's completely normal on the MZ-7.
Dec 02, 2009 | Pentax MZ-7 Film Camera
The Pentax MZ-6 had no sign of current while switching it on.
Send it in for a repair if it's worth to you. There can be quite a lot of things wrong with the electronics.
Jan 11, 2018 | Pentax MZ-S QD 35mm SLR Camera
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
Jun 06, 2009 | Pentax MZ-M 35mm SLR Camera
PENTAX mz 50 I WAS TAKING A PICTURE WITHOUIT ROLL
Just a guess, but it sounds like the shutter is stuck in the closed position. Maybe you can have the camera serviced. Try to find an online film enthusiast club, such as on Facebook and elsewhere. They might be able to direct you to where you can have your camera serviced. I can tell you that the cost of that camera is about $100 used, and repair might be the same price, so it might be better to buy another one off eBay. They have MZ-50 models for sale and lots of others. Film gear is cheap these days, but repair is not cheap. Better to buy another camera. I'm sorry about your problem and hope you can resolve it. If this was 10 years ago, you'd have a warranty and could have it fixed, but these days it's just easier to buy another camera and probably the same price or cheaper to buy another used/second-hand camera than to pay for repair. Good luck to you.
Apr 06, 2009 | Pentax MZ-50 35mm SLR Camera
Shutter won't click, Films Winds back in canister.
Yes.
Shutter motor is bad and needs replacement.
Apr 01, 2009 | Pentax MZ-M 35mm SLR Camera
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
I cannot load the film into my pentax mz 60 it keeps showing the error message. I have no trouble loading the film into my second camera (same)
rootseya,
pentax error codes are in the repair manual for camera repair technicians. the camera needs repaired.take or send your camera to a camera repair shop for an estimate.
Shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Oct 25, 2008 | Pentax MZ-50 35mm SLR Camera
Pentax MZ-50 35mm SLR Camera Logo
656 people viewed this question
Top Pentax Photography Experts
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
