Question about Koss KS4110 DVD Player
No Picture on my TV
My son was playing with the DVD remote & now I don't see any picture, but sound is clear. Don't have the actual manual and hence don't know how to reset it with the remote. Any help will be appreciated. Regards
  • 1 more comment
  • survij2 Dec 10, 2007
    My son used Panasonic DVD player for better picture. I want to switch it to Koss KS4110 for using VCD and looking the picture slide show.
    I do not have manual for KS4110. I connected red and white cables from TV resp. audio terminals. I do not know where to connect DVD/Y,DVD/ CR, and DVD/CB cables. I connected to Y CR/PR and CA/PA.
    I get audio but no video at all.
    Please some one tell me if the connection is wrong or the KS4110 is not working.
    I used this unit previously for slide show as well as DVD, and VCD.
    Thanks.
  • e0055042 Jun 12, 2008
    I have a Koss DVD player KS4110, the sound is clear but there is absolutely no image. I tried the V.Select button, that didn't work and also unplugging it for 24 hrs did not work. I tested the wires and they work perfectly.
    Any help would be enormously appreciated
    Thank you
  • TCole Jul 23, 2008
    I have a Koss KS4110 DVD Player and changed to display from NTSC to PAL not knowing that I wouldn't be able to revert the changes. I have no manual and have tried the "Select" button with CD tray opened and closed. I'm hoping there is a code that reset to Factory Default. Please Help!
    TC
I had the same problem last night. On the top row of the remote, just next to the red power switch is a button that says v.select. I pressed it and the image returned to the screen.
Posted on Apr 20, 2007
Norcent dvd home theater plays good sound, but no picture
check that ur video input on the tv is set correctly. you can do this by turning on ur theater system first , when u get ur sound grab the tv remote and select the tv input button or if u don't have said button try thr tv/video button untill u get a picture. ( this of course a suring that ur video cable is connected ) hope that helps
Jun 03, 2012 | Norcent Technologies DP-2700 System
Hello. I contacted you earlier, your email went to my spam. I missed it and cancelled . Sorry. The problem. I have is a ghosting picture of a program I watched earlier. The problem comes and gos....
Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Jan 25, 2012 | LG 50PC1DRA 50 in. Plasma Television
Whar channel should be on to play a DVD?
It depends on which input you have the DVD plugged into. The pictures below show the different inputs. One of those should match what you see on the back of your DVD. If you don't know which, you can turn on your DVD player and hit the INPUTS button shown on the picture of the remote control shown below. Or, if it's connected to one of the inputs pointed to by the DIRECT SELECT arrow on the picture of the remote control, you can go there directly from watching the TV. phillip_d971_1.jpgphillip_d971_2.jpg
Apr 12, 2011 | Zenith Z50P3 50 in. Plasma TV
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
SCREEN PROTECTOR BROKEN
actually replace the same type with serial numbers.
Jun 15, 2009 | Philips 55PW9363 55" Rear Projection...
Samsung HCL4715W
IF THE CONVERGENCE IS NOT ADJUSTING COMPLETELY THEN IT PROBABLY NEEDS NEW CONVERGENCE IC's . ALSO CHECK OUT THE SHARPNESS OF EACH PICTURE TUB (CRT) THESE SET ARE NOTORIOUS FOR HAVING BAD CRT''s (WHICH ARE NO LONGER AVAILABLE).
DON.
Nov 06, 2008 | Samsung HCL4715W 47" Rear Projection...
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Protron PD-800 DVD player
On the remote control of the DVD player, just press the P-scan, reset or video SW button.. That would fix it... If you have screen kumping problem then please try this following steps... Press the setup Down arrow once Enter Down arrow 1 time Enter Up arrow 1 Enter Set up
Jul 04, 2006 | Protron PD-800 DVD Player
Koss KS4110 DVD Player Logo
140 people viewed this question
Top Koss Televison & Video Experts
Marvin
Marvin
richochet
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
