Question about Jenn-Air JED8430 Electric Cooktop
Cooktop will not get hot
I had all 4 burners on high trying to boil water. There was a small amt of water on the bottom of my pans when I put them on the burners. I smelled a burning smell and then my burners will not get hot again. When I turn them to the on position, the lights under the knobs on the cooktop light up, but the burners do not heat up.
  • mb190794 Dec 31, 2008
    Turned on all 4 burners, blew a fuse under cabinet, not breaker. Replaced, fuse blew again. Everything works lights, fan but have no heat in any burners.
    Is there an internal fuse?
    Thanks for your advise / help.
  • 71 Answers
Wire conections to ct from house wiring may be loose check conectors
Posted on Dec 24, 2008
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Burners of electric cooktop not getting red hot
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Will burner get too hot
Hello Pinewood7. The issue here is concern from what you have heard. Don't worry! All you are doing is boiling water. The system will allow constant heat for what you are doing. Use this as a test. Put your largest pot on the top full of water and set on high. Attach your thermometer to the side and see what happens. I know several people who use these tops for canning with excellent results. My sister in law has had yours for years and not an issue with jams. Hope this helps with your concerns.
Aug 09, 2008 | Jenn-Air Expressions AR141 Electric...
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. back.
Sep 23, 2006 | Jenn-Air JGC9430 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
291 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
