Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My computer will not boot up if my WD500 is connected.
If i disconnect the WD500 it will boot up just fine, i can then connect the WD and it works fine.
OS: Windows XP
    Problem Solver:
  • 6 Answers
You will have to go your BIOS settings. What its doing is the BIOS is looking for a removable storage to booot to before it looks for your actual hard drive. You will have to change the order of boot checking to where your hard drive is first.
Reboot your computer without the drive connected.
While still on the black screen that looks like DOS, it should come up and say press F2 (or some other key) to get to SETUP.
Press the key rapidly until the screen comes up.
If it dosnt come up then you were to late and then reboot your system and start pressing it repetadly agian right when it turns on.
Navigate in your BIOS menu to find BOOT OPTIONS.
Once there rearange the list to where IDE or HARD DRIVE 1 is first on the list.
Press the exit button and make sure to save chages not discard them.
Then try connecting it and turning on.
Posted on Dec 24, 2008
Why is not my WD500 eSata hard drive doing nothing after it is connected via a USB cable to my laptop?
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Aug 16, 2017 | Western Digital Computers & Internet
Battery disconnected and key wont go into lock
There is a hot lead on the starter you can jump to from underneath.
Aug 16, 2017 | 2000 Mercedes-Benz S-Class
My newly purchased WD External HDD 1.5TB USB blocks the start of my PC (XP SP3). Not even the BIOS can be reached. When disconnecting before start en later connecting de HDD, everything works fine. What to...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 29, 2010 | Western Digital Computers & Internet
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Prolem with starting my WD500 (model wd5000h1u-00)
Okay this is a internal SATA drive so what you can do is take it out of its failing case and put it into your computer or buy a new enclosure for it. I have a Mybook TB drive and my works great with no problems. But you can take this to WD western digital as its warrentied foe 3 full years!!
May 25, 2009 | Western Digital My Book Home Edition 500...
Problem accessing WD Passport Elite drive
The solution to this is associated with the power supplied by your laptop to the drive. It seems the passport drive needs about 1000mA of current which will be supplied by two USB ports on a laptop. It should be fine with a desktop USB port though is what I was told.
Feb 24, 2009 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
186 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
