I can't find the manual and this is the first time I've used it but only the toaster section works. When you turn it to bake or broil if flips back to toast.
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
SOURCE: I need a manual for my toaster oven broiler
My B&D stainless appliance rusts? None of my Cuisinart's do.
SOURCE: Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
SOURCE: User Manual Oster-Toaster-Oven-Broiler-6233
If manufacturer site is of no help, check here, they have the Oster 6233 manual for download.
I couldn't find your manual on Magic Chef's site - are you sure you copied the number correctly?
Magic Chef Customer Service will probably be able to help you and can be reached:
Customer Service: 800.688.1120
Canadian Customers: 866.587.2002
553 Benson Road
Benton Harbor, MI 49022
