Question about Toshiba 50HP66 50 in. Plasma Television
Pink line down middle of screen
Just noticed a pink line down the middle of my Plasma 50HP66. I cannot get this to go away. The TV is only a little over 2 years old, no children, very little, if any video game use. What can I do?
Thanks
  • 6strings57 Mar 25, 2009
    I have the same problem, talked to toshiba, they said it was a first, that they heard of, did not offer solution, mine also is 2 years old
  • suttonplace Apr 12, 2009
    Same problem here. Really pissed off !! Almost 2 grand, no abuse at all, hanging on same wall since we got it. I will never buy Toshiba products again !!!
  • 298 Answers
SOURCE: No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Posted on Nov 22, 2007
  • 3 Answers
That problem is caused by the Y Sustainer board.
Posted on Apr 05, 2008
  • 2337 Answers
SOURCE: Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Posted on Apr 28, 2008
jerryg50
  • 1689 Answers
SOURCE: Toshiba 50HP66 50 in No Picture/Only Sound
Most likely a power supply failure, and or a failure on one of the other boards that is causing the shutdown.
The set will need service.
Jerry G.
Posted on Apr 30, 2008
  • 224 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
My toshiba 50 inch plasma tv model 50hp66 powers on but has no sound or picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 18, 2015 | Toshiba 50HP66 50 in. Plasma Television
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
Pink and green lines running horzontaL
You need to change the buffer driver boards both upper and lower. You can get them here: CLICK
To install them requires opening the back cover of the TV...
http://tvtechwork.webs.com/
Oct 19, 2010 | Toshiba 50HP66 50 in. Plasma Television
Multi colored strip running thru tv
I'm affraid to say that your screen has got a PDP/LCD fault. Just like a tube going on a TV. This is a fault which is beyond economical repair
May 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
50HP66 50 in. Plasma Television: i have red dots/shadowing on my tv...
I got the red dots really bad on my toshiba 50hp66 after an hour or two of watching tv. I found out that if you open up the tv in the back on the left you will find two adjustment pots labelled Vsc and Vy. I took a sharpie and marked where the factory defaults were first. Then I adjusted the Vy pot down a little bit and the red spots were gone! My tv looks great again!
May 16, 2010 | Toshiba 50HP66 50 in. Plasma Television
There is a green line going down the middle of my screen. What does this mean?
My best answer there would be a defective display panel. It will not be worth repairing.....
May 07, 2010 | Toshiba 50HP66 50 in. Plasma Television
We have Toshiba 42" Plasma TV about 4 yrs old. The past couple of weeks we've noticed that there is a horizontal rolling band of pinkish color (about 8-10" band.) We really notice it when there are people...
Im pretty sure its not the television. You are getting interference from either through your cable box or your electric in the house. Possible bad dimmer switch.
Dec 14, 2009 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
My Toshiba 50HP66
It sounds like you have a fault on the picture frame board and for a competant technician this is not much of a problem. Or it could be something as simple as dry solder joints. Either way the tv can be saved and is worth fixing. Hope this helps.
Oct 07, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 50 in. Plasma Television Logo
285 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
