Question about Maytag SAV4655A Top Load Washer
Tub fills with water but will not aggitate once filled
Top loading wash machine is about 17 yrs old....i just washed a load then went to do another load, machine filled with water but that was it; could it be the timer gone bad?
  • 71 Answers
Lid switch
Posted on Dec 24, 2008
Admiral washing machine will fill won't spin
You have possibly 2 senarios there. One is possibly your capacitor is defective and two if cap is good, your main motor is faulty.
May 20, 2010 | Admiral AW22 Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Water comming from under washer front side
 Check the following:
Are the fill hoses tight?
Are the fill hose washers properly seated?
Is the drain hose clamp properly installed?
 Is the sink or drain clogged? Sink and standpipe must be able to handle 17 gal. (64 L) of water per minute.
 Is water deflecting off the tub ring or the load? Center the tub before starting the washer. The wash load should be balanced and not overloaded. The fill or spray rinses can deflect off the load. The washer must be level. The front feet should be properly installed and the nuts tightened. Reset the
rear leveling legs (if needed).
Mar 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore top load will not fill. It aggitates when it should fill!
your experiencing an issue with your pressure switch. it thinks its full of water, so its going rith to the agitate mode. you would need to remove the back panle, and the pressure switch/fill switch is conected to a thin plastic tubing, reomve the tubing and blow through it, you should either here it gurgrle( through the water in hte tub, or air depending on water level. after clearing the line resecure the hose and see if that helps
Feb 26, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag SAV4655A Top Load Washer Logo
170 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
