Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Removing Doors on Whirlpool Gold GS6NHAXVQ side by side fridge
I need to remove the doors on my new fridge. It has water lines in the door and I can't find directions on how to properly remove the doors. Electrolux does a wonderful job explaining this online, but I can't find anything on Whirlpool models. Trying not to demolish the kitchen entryway!
  • 700 Answers
When you emove the kicholat there shoiuld be a coiu[pling on the water hose that you take off and pull the tuding out of the door hinge .. hope that this works for yo. Thank you for usinf Fixit and Merry Christmas
Posted on Dec 24, 2008
  • 71 Answers
Remove the kick plate (lower grill) on the freeezer hinge is a tube folow that tube to a disconect, unscew the nut then remove the nut from the tube then remove the top hinge and lift the door off the lower hinge threading the tube through the lower hinge.
Need to remove doors from a Shelvador side-by-side fridge to get into house.. How to disconnect water line to door?
Most of the water lines have a quick connect fitting down at the bottom under the unit. Open doors, remove kick plate and follow line back. Should have a connection in that area.
Aug 18, 2012 | Refrigerators
Want to remove the doors on my side by side whirlpool fridge have icemaker and water in door
When removing doors with an ice maker. Under cover on top off unit there is an electrical hook up, unplug it. then at bottom of freezer door there is a water line, it has a quick connect on it. Push in to release then pull apart. Take screws out of top hinge and remove door. Same on refridge side, just no wires or water line.
Sep 27, 2010 | Refrigerators
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
How do iremove the doors on my conquest
Remove the hinge cover at the top for both doors . Remove the bottom kick plate from the fridge . On the freezer door , follow the white tubing at the bottom about 6" to a connector . Remove the hose from the connector . Unplug the receptical at the top of the freezer door and remove the 3 screws from the top hinge . Lift the door upwards , pulling the bottom tube thru the bottom hinge . For refrig door , just remove the 3 screws holding the top hinge and lift door off bottom hinge . Hope this was helpful .
Aug 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Want to move whirlpool american side by side fridge freezer but need to remove doors how is this done
1. If you just need to gain a little space you can simply remove the door handles. They should just lift (or slide) up with moderate force and can be removed.
2. If you only need to move through one door in a building you might be able to open the doors enough to make the unit clear the door you are trying to move the unit through. This would take care.
3. If you really do need to remove the doors, be sure to disconnect the water line at the rear. Then gently snap off the hinge assembly covers at the top of the unit and disassemble the hinge. Be aware of water lines when you are ready to remove the doors.
dwilli10
Jul 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Uneven doors on a new whirlpool gold frigerator
You need to adjust the rollers on the front of the unit. This will even up your doors.
Apr 11, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whirlpool Side-by-Side Fridge
unscrew the cover plates on the top door hinge there are quick connects for the elects and 3 bolts on the freezer side and just 3 bolts on the refg side before you removed the freezer door pull the kick plate and there is a water line quick connect you will need to disconnect it as the tube runs thru the hinge after the top bolts are out pull up on the door and it is off >>>Note: there are some small plastic washers on the hinge post make sure you dont lose them
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
306 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
