Fan is turned to face up ( vertical venting ) BUT Very little air is drawn from bottom vents. Most of the air is drawn from the top louver... which is otherwise the output if set up for recirculation.
I would direct you to first refer to your installation instructions to be sure everything is installed correctly.
Then I would refer you to the owner's manual for information on checking and cleaning / changing the grease filter or charcoal filter.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
If you need further help, you can contact Electrolux at 800-944-9044.
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
