Question about HP 530 Notebook PC
Cannot get the laptop to boot up with battery power
I cannot use the laptop on battery power only, it will not boot up on battery if you boot up with power it will run but only for a short time on battery. The computer is new
  • Anonymous Jan 03, 2009
    My laptop is doing the same thing....if yours is new you should return it there is a 1 year warranty....mine is a year old so no warranty left
    Problem Solver:
  • 3 Answers
There are allegedly at least ten million dodgy lithium ion batteries out there and subject to recall. Claim on your guarantee.
Recently I was pestered into getting a cheap used laptop for a yachtsman. He wanted it to run a charts program but when tried on battery it only ran for half an hour. After an overnight charge it ran for 2 minutes. The computer store that originally sold it when new tried it on their test battery but it still wouldn't boot. They said the laptop was no good. By now the complaints were giving me earache but a new battery was on its way from China. It wouldn't boot on that one either, quitting after several seconds. To shut the blokes rattle I gave him his money back. What was very odd was the fact that if mains power was used during boot-up, a whole DVD movie could be played on battery! This would indicate that the lithium ion cells are OK, very strange. To try to salvage something out of the mess I bought a similar model spares-or-repair on eBay. To my amazement the battery from the scrap laptop boots my laptop (Advent 7016 AKA Gericom Blockbuster N251S6) no problem. Allegedly these "smart" laptop batteries have safety trip circuits built in to prevent them from catching fire. If the current trips are set too low the laptop won't boot-up as empirical results indicate that booting-up uses a lot of current, (its a bit like starting a car).
In my case it was in effect 4th battery lucky, so I don't have much faith in the computer shops technicians who said the laptop was no good. Putting WindowsXP SP2 on and doing a defrag also helps and a new coin cell for the BIOS is also a good idea. This machine really flies now!
With a decent battery your laptop should boot OK even when the battery is only half charged. Good Luck!
Posted on Feb 26, 2009
  • david_benyon Feb 26, 2009
    I forgot to mention that a friend once purchased a new camcorder that had had its new OEM battery switched for a used one that was on its last legs. I wonder how that happened! Incidentally these Lithium Ion batteries are only expected to last for 400 to 500 charge-discharge cycles and they don't like heat.
    President:
  • 2,692 Answers
I agree . Return it . Is seems to have a bad battery or connection
Posted on Jan 21, 2009
My gateway laptop won't startup. It's taking me to a Insydeh20 utility screen
If unable to boot follow the below steps:
-Remove the battery and Power adapter
-Press and hold the power button for 30-45 seconds (with battery and power still removed)
-Insert just the battery and attempt to boot the laptop.
-Insert just the power adapter and attempt to boot the laptop
This may work I have not tested this as I have not got a gateway laptop
Cliff Cook
Jul 30, 2014 | Computers & Internet
My samsung n150 mini, was working very well.suddenly, the screen turns into black and no sound of the processor. Screen and battery flashlight indicates that they dont work.what is happening?
Does the laptop start up with power adaptor plugged in?
If yes then battery may be dead, you can check for a replacement online, battery model may be AA-PB2VC6B but check the battery label to ensure you note the correct battery model.
If the laptop does not boot with the power adaptor inserted, remove the battery and try booting with just power supply inserted and see if laptop boots.
If still not booting then it is a hardware fault, either battery, power adaptor or internal part possibly motherboard, you will have to contact Samsung for repair.
Good Luck
Jan 10, 2013 | Computers & Internet
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Powere adaptor has to be unplugged to boot
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 22, 2009 | Dell Precision M90 Notebook
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | HP Pavilion Dv5220us Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
No power to the laptop when plugged in
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only and see if the laptop boots up without the battery, go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Dell Latitude D510 Notebook
New dell laptop dosn't boot from battary ,power cable shoud be pluged
  • two ways to charge the battery:
    • while the laptop is on
    • while using the laptop with a power cord, but it will take charging time when you are using the computer.
  • --if the problem persist, the battery may have a problem, called dell technical support and have the battery serial number for possible battery recall. or replacement
Apr 16, 2009 | Computers & Internet
HP 530 Notebook PC Logo
270 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
