Question about Recoton Advent Advent Q2035A 20" TV
Analogue tv tuner card
I CANNOT GET A TV SIGNAL FOR MY COMPUTER.MY ARIAL IS A ROOFTOP ARIAL WITH A STRONG SIGNAL,BUT CONFIGURING IT MAKES NO DIFFERENCE.CHECKED CONNECTIONS AND TRIED SEVERAL TIMES TO RE-INSTALL TV SIGNAL,BUT WITH NO JOY! PLEASE HELP!
Then check signal wirecable other change it or call to operator
Posted on Apr 28, 2007
SOURCE:
How do I attach a flat leaf antenna to an older Phillips TV
The old style TV's need a converter box. You cannot just hook up an antenna directly to the TV. The TV signal in the air is now digital. Your old style TV has an analogue TV station tuner. The converter box transforms the digital signal into a usable analogue signal. Just do a online search to find out any information that you need.
Oct 18, 2015 | Televison & Video
I do not get any channel when i search even though all the connections are ok
Is this an analogue or digital tv tuner card.
If it is not a digital tv tuner card you wont get any channels.
UK has gone fully digital now and you need a digital receiver(freeview)
If it is a digital receiver you may just have a poor signal from your ariel
Jul 11, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Is this model digital
You don't say which model or make the TV is and we are not mind readers at FixYa.
However most TV's made that are digital have on the menu somewhere digital and analogue, because they have two tunners. If you look at the set-up menu and don't see digital set-up or something like it, then chances are it's not digital. If not then the only way you can watch this TV is with the box you mention.
Feb 01, 2010 | Televison & Video
I am trying to connect my DMR E55 DVD recorder to my Viera 32LX TV and take the satellite signal from the TV and the recorder is reading nothing. I am using optical cable and a SCART. What am I doing...
To hook up you need to go from the satellite box to the recorder then to the TV. If you do that then you should be able to record the show on Tv. You can get the manual on the link below. Page 7 tells you how to hook up.
http://www.hollywoodstudiorentals.com/uploads/030708__Panasonic_-_DMR-E55%5B1%5D.pdf
Dec 30, 2009 | Panasonic DMR-E55 DVD Recorder
Hi friend, My SONY VGC-LV250 only analog tuner can get signal,digital tuner does not work at all. Is there some setting wrong? I try my indoor antenna already. it works on other HDTV pretty well.
The signal strength needed for digital tv is slightly great for terestrial TV I assume the HDTV you are talking about is a player. First you need to test the unit on a known good arial if this works ok then you have two options get a better internal arial or get an external arial. The other option is to get an signal amplifier for the arial you have but there is still no guarrantee. Best option is a Digital arial the are designed to give the best signal strength thus picture.
Hope this Helps.
Dec 24, 2009 | Sony VGC-LV250J/B PC Desktop
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
No signal
Try video input using a dvd - if you are using a digital cable box (or satellite) use the a/v outputs (yel red wht wires)to hook to video in of TV. If you are using standard cable hook the cable through a vcr if available and hook the a/v of the vcr to video in of the tv.
Otherwise is tv(to be used) on Ch3?
The TV tuner may be defective.
If this helped Vote/rate me.
Oct 05, 2009 | Televison & Video
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
DVB not working on panasonic TX26 LXD52. Can't change channel nor access any menu's, guide etc when in DVB mode. Analogue tuner and av functions working fine. Remote works fine in analogue mode with...
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Apr 30, 2008 | Panasonic Televison & Video
Recoton Advent Advent Q2035A 20" TV Logo
50 people viewed this question
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
