Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Year my tv was made
Sharp tv model=avm25786-serial number=v8370436900028when was this made?
  • Anonymous Feb 16, 2009
    do i need a converter box if my APAX tv, made in 2002
All of a sudden my purifer is no longer working I have notice the ceiling aboe were my purifer sits the ceiling is getting dark so I shut it off , it just not seem to clean the air anly longer my serial...
These units are manufactured by Alpine Air Products. Some years ago, they were sold through Network Marketing Reps.
You can contact Alpine Air Products directly at 888-675-2616, Monday - Friday (9am - 5pm PST).
That will be your best bet.
Feb 22, 2011 | Ecoquest Fresh Air Air Purifier
My Breeze AT by EcoQuest , Model Breeze AT, Serial AT 125386, is sizzling the only ozone plate it has. A sizzling sound and a visual inspection shows it has a heavy concentration of voltage near the...
DO NOT USE IT WITH A DEFECTIVE PLATE!!!
It should be used with 2 plates. Order new plates IMMEDIATELY. They aren't too expensive, and hopefully will save your machine if it hasn't been damaged too severely.
Call Vollara (new name for EcoQuest) (1-800-989-2299) and use #16618 as your Dealer Referral number.
Jan 24, 2011 | Ecoquest Breeze AT Living Air Purifier
I am getting a message that says replae RMI Cell. What does this mean? model # fresh air 2.1 serial #267523
Hi.
The RCI Cell must be replaced about every three years.
The part costs about $90, parts available here.
Replacement is explain at page 15 in manual available here.
There is also a debate on health concerns related to ionized air purifiers. Here Ecoquest answer, stating the product is safe.
On the other hand:
The Dangers of Ionic Air Purifiers
Ionic Air Cleaners
Regards.
Ginko.
Sep 23, 2010 | Ecoquest Fresh Air Air Purifier
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what...
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Apr 25, 2009 | Air Purifiers
REPAIR ON MY FLAIR
Hi Bonni,
If you bought it new from EcoQuest, the record should be available from EQ Customer Service, or from the Dealer you purchased it from. You should have received (and filed) a warranty card. They should be able to verify who sold it by the serial number, and give you warranty information from that.
Since we techs here at FixYa aren't employed by EcoQuest, we don't have access to the serial number records; you will have to contact the EQ Customer Service there as well.
As for the repair, you would have been given an RMA (Returned Merchandise Authorization) number; without this, you may have difficulties with EQ, since this is how repairs and returns are tracked. Did you deal with this personally or through a Dealer? In any event, they should be able to cross-reference it by serial number and date of service.
EcoQuest Customer Service is at 800-989-2299, or at
customerservice@ecoquestintl.net
if you prefer email.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 05, 2008 | Ecoquest Flair Air Purifier
Unit does not work even tho blue light shows its on
The bad news is that Sharper Image filed for bankruptcy this year closing all their stores. There unable to honor the warranties on the units and even recalled all Ionic Breeze units.
Here is a link as to what happened to the company:
http://www.aircleaners.com/sharperimage.phtml
You can still get parts for Ionic Breeze at this link:
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKfhotf9_JYCFRxNagodHR10Yg
It could just need some new plates for it.
Nov 17, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Living Air Classic Electronic Air Purification System Model XL Serial C260814XL
The problem is corrected, Thank You. I had spaced my numbers on my credit card, therefore it made it invalid. I found out about this, and re-ordered using the numbers with no spaces, and my order is placed and on it's way. Thank You very much for all your help. This is a terrific site for people with a problem. Very good service.
fastflo
Mar 29, 2008 | Ecoquest Living Air Classic Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
499 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
