Question about Pioneer VSX-1016 Receiver
I have a Pioneer VSX1016TXV-K receiver & the remote doesn't work
My remote seems to be sending a signal to the receiver but it won't work the receiver. I can manually use everything on the receiver. I talked to Pioneer and I told them I think I need a remote sensor and they sent me a tuner knob. I told them that wasn't the problem and now they are telling me to order some type of switch. I don't think this is the right part either. Does anyone know if you can get a new remote sensor or if not is it likely something else?
    Top Expert:
  • Pioneer Master
  • 28,699 Answers
It is unlikely to be the sensor. Could be the wrong code from the controller.
Posted on Jun 17, 2017
5 Suggested Answers
SOURCE: Need a user manual for my Pioneer Elite VSX-07TX
I have this receiver, and just scanned the manual for an individual. If you still need a copy of it, let me know and we can figure out how to get a copy to you. Regards, Berry bcaddell@icsystems.net
Posted on Jan 12, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
Posted on Apr 24, 2009
ABKSeeker
  • 69 Answers
SOURCE: Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
Posted on Feb 14, 2010
drifterK
  • 4924 Answers
SOURCE: Yamaha YST-99CD. I thought
http://www2.yamaha.co.jp/manual/pdf/av/english/zot/YST-99CD.pdf
This is the manual for this unit..and it seams (as described at ..controls ) it only have controls for time setting on the remote ..(the buttons with H and min ) So ..if there are no buttons like that on the main unit ..the set time is impossible without the remote ..
I believe the problem with your unit is the remote sensor....and not the remote itself ..
Posted on Aug 26, 2011
What to do if PIONEER DVR-940HX is not responding at remote control comands
Have you tried a cheap universal remote just to verify the receiver is working for the infrared remote signal?
Jun 21, 2016 | Pioneer Televison & Video
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
Jan 20, 2013 | Pioneer Elite VSX-32
The remote to my aircon doesn't seem to be sending a signal
If you get a mobile phone and select its camera, then look at the LED at the front of the remote thru the camera, press some keys on the remote unit and you should see the LED light up on the remote on the mobile phone camera screen (it picks up Infra Red which we can't see). this will let you know if the remote control is working. if it is, the receiver at the indoor unit is either covered with something, check thoroughly, or the receiver is faulted, replace via technician. Have fun Tim B TB Electrical
Nov 29, 2012 | Carrier Heating & Cooling
Pioneer vsx-d810s only dvd 7.1 input works and static on all other inputs
Try resetting the receiver the Pioneer Web site should have the reset procedure for your model if that doesn't work time to send to the shop.
Oct 03, 2011 | Pioneer VSX-D810S Receiver
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
Buttons won't work it seems it doesn't send the signal to the receiver.I got new battries but still won;t work
Try to check the remote Model matches the Receiver's model number. If it does not, then try to get Universal Remote Controller
Jan 30, 2010 | Denon RC-H800 Remote Control
Doesn work at all
I've had the same problem. Get the technical assistance phone # out of the manual that came with the fan. They can give you the proper part # so that you can then call Home Depot and special order the receiver. However, I have done this and then installed the new receiver as advised by Hampton Bay and I still am unable to get the remote to operate the fan or the lights. I know the fan works becaue I bypassed the receiver and wired directly to house power. I don't know if perhaps I have a bad transmitter (remote). I'll try that next. The fan worked for about a year, now its just a headache.
Jan 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote not working receiver on Pioneer vsx1016txv-k
Request a service manual directly from Pioneer.
May 09, 2017 | Audio Players & Recorders
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Pioneer VSX-1016 Receiver Logo
114 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
