Question about Motorola Mobility HS850 Consumer Headset
Headset failed to transmit
My headset failed to transmit upon receiving calls. I am able to hear my party answer whenever I placed a call, but they are not able to hear me.
    President:
  • 379 Answers
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.happened to me a lot . hs850
Posted on Dec 24, 2008
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up , did this imformation FIX YA ? thanks for voting .
Static and cant hear on the phone
Plug in a headset to the phone. Does the call sound normal with the headset? If so, you may have a bad speaker on the phone.
Mar 25, 2014 | Apple iPhone 5c
When I receive a call I can not hear the other party, just started this morning
hi, its possible the earpiece of your phone is faulty...but for now you could try to put your phone on speakers whenever you want to recieve calls or make use of headset...
cheers
Jul 05, 2011 | Cell Phones
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
I am able to call but can't hear the other persons phone ringing, busy, voicemail or if anyone answers, there is no sound. The same if someone calls me, it rings, I try to answer & nothing. I can send...
well the ringing is from another speaker that works as a loudspeaker/ handsfree on your phone
as a preliminary check try connecting a headset and answer the phone if you can hear the other party then the problem is with the earpeice, you might want to get it repaired
Jul 22, 2009 | Motorola Mobility RAZR V3
Outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Can't hear or be heard during phone calls
This is a known promblem with the treo phones.
If you had a wired headset plugged in to your phone then removed it. The phone thinks the headset is still plugged in. Try putting headset back in phone and removing it. You may need to do this a couple of times. If it still doesn't solve the problem make sure your bluetooth on the phone is turned off. If problem still exists you may have to contact your carrier for replacement.
Good Luck,
trweekes
Aug 24, 2008 | Palm Treo 755p Smartphone
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
Hi
The first 2 answers sound relay dumb but always start at the beginning when diagnosing a problem. 1: make sure you're not placing your thumb over the Mic (located at the bottom, front of the device). 2: make sure Mute is not turned on, if it is tap it to turn it off. 3: if your using handsfree mode try picking the phone up and using it normally. There's no Mic volume control in the standard Matchbox based GUI but some 3rd party software does include volume adjustments so take a look at your settings in any control apps you have installed. lastly see if you get the same problem using a headset, you have not said if you are using the phone normally, with a headset/BlueTooth headset or in handsfree mode. Post back if non of this helps.
Aug 23, 2007 | Motorola Mobility A1200
Motorola Mobility HS850 Consumer Headset Logo
181 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
