Honeywell VisionPro 8000 cycles between Hot and Cold all day.
I have 4 Honeywell VisionPro 8000 controllers controlling 4 commercial HVAC units.
They are all programmed to AUTO setting and cool above 72F and Heat below 69F. 3 of them work well but one of them, for the last several months, constantly switches from hot to cold and back. It basically keeps heating till well past 69, actually way up to 76 or more, then the AC comes on and cools down to 65 or below when the heating starts again. Is this something that can be fixed easily or is this likely to be something requiring warranty service?
  • 700 Answers
Yes it sound like either they wired it wrong or when theywent and configured the settings this obe did not take to the configuration correctly. Have the contractor come back and do the job correctly or replace the thermostat. Thinks for using Fixya
Posted on Dec 24, 2008
Is there a battery in the t8000c thermostat the screen is blank
There should be a couple of AAA batts in it. Grab all 4 corners and pull straight out & off the mounting plate. If no batteries are installed it is hard wired & the problem is at the air handler(blown blade fuse or open transformer winding). When you reinstall batteries make sure there is no corrosion. And careful when you put the tstat back onto the base. There are some small pins that need to align with its holes/terminals. Honeywell has a great 1-800 support #. Should be on the tstat.
Jun 28, 2015 | Honeywell TH8320U1008 VisionPRO 8000...
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
Our visionpro 8000 thermostat has adjusted its day. It is currently one day ahead. We have misplaced our manual and we cannot seem to get the day to change. Suggestions?
This site has owners manuals for different types of thermostats. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/VisionPRO+8000.htm
This site is the manual for the "VisionPro 8000". You can look up what you need, copy or download. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf Roger
Apr 07, 2011 | Honeywell Heating & Cooling
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
